1. Budget & Location
1700Euros ~ 2000$
Austria/Germany Europe - you can give me pcpartpicker lists from America too and i will fit it then with my local stores or so.
2. Aim
This Build will be used for gaming + upcoming Video Editting so people say the i7-4790k is good for that use
3. Monitors
Would like to have the BenQXL2420Z
4. Peripherals
Already got Mouse,Keyboard and Headset. Will get the Windows 8.1 OS for 21Euros from G2A for 1 year and switch to windows 9 then
5. Why are you upgrading?
I am Upgrading because i want to make my first ever build. I had a prebuild PC with a i3 right now so I want to upgrade.
Thx guys already in advance
https://linustechtips.com/topic/213299-first-build-need-help-noob/
1700Euros ~ 2000$
2. Aim
3. Monitors
4. Peripherals
Any reason why you need that monitor specifically? It's fairly expensive, so I'd change to a ASUS monitor with similar spec instead (144Hz Refresh rate as well)
CPU: Intel Core i7-4790K 4.0GHz Quad-Core Processor ($339.93 @ OutletPC)
CPU Cooler: NZXT Kraken X61 106.1 CFM Liquid CPU Cooler ($139.99 @ Newegg)
Motherboard: MSI Z97-G45 Gaming ATX LGA1150 Motherboard ($128.98 @ SuperBiiz)
Memory: Corsair Vengeance 8GB (2 x 4GB) DDR3-1600 Memory ($89.99 @ Newegg)
Storage: Samsung 840 EVO 250GB 2.5" Solid State Drive ($118.99 @ Best Buy)
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive ($79.99 @ Amazon)
Video Card: MSI GeForce GTX 780 3GB TWIN FROZR Video Card ($453.98 @ Newegg)
Case: Corsair 450D ATX Mid Tower Case ($99.99 @ NCIX US)
Power Supply: EVGA SuperNOVA NEX 750W 80+ Gold Certified Fully-Modular ATX Power Supply ($69.99 @ NCIX US)
Monitor: Asus VG248QE 144Hz 24.0" Monitor ($264.99 @ Amazon)
Total: $1770.82
Generated by PCPartPicker 2014-09-11 12:17 EDT-0400
My rig: Intel Core i7 4790k | MSI Z97 PC Mate | GSKILL Ripjaws X 16GB 1866MHz | ADATA Premier SP550 480GB SSD | Seagate Barracuda 3TB | Seagate Barracuda 2TB  | MSI Gaming X GTX 1070 | Thermaltake Versa N21 | Corsair CX550M Semi Modular PSU | AOC G2460PF 144Hz | Logitech G502 | GSKILL Ripjaws KM780  | GAMDIAS HEPHAESTUS V2  PCPartPicker | Old Build Log | New Build Log
Total: $1770.82
People say it is the best gaming monitor what is out there right now and they also say it is worth the money
Why do you suggsest the Segeta Barracuda and not a WD Black like alot of people do?
Btw the X61 is not available and will not be worth the importing. So should I go for a H110 from Corsair then?
CPU Cooler: Corsair H105 73.0 CFM Liquid CPU Cooler  ($99.99 @ Newegg)
Motherboard: Gigabyte GA-G1.SNIPER Z97 ATX LGA1150 Motherboard  ($155.91 @ Newegg)
Memory: Patriot Viper 3 16GB (2 x 8GB) DDR3-1866 Memory  ($151.98 @ Amazon)
Video Card: Asus GeForce GTX 780 3GB DirectCU II Video Card  ($418.99 @ SuperBiiz)
Case: Phanteks Enthoo Luxe ATX Full Tower Case  ($149.99 @ Amazon)
Monitor: BenQ XL2420Z 144Hz 24.0" Monitor  ($324.00 @ Newegg)
Total: $1905.82
Generated by PCPartPicker 2014-09-11 15:04 EDT-0400
CPU: Intel Core i7-4790K 4.0GHz Quad-Core Processor  ($339.99 @ Newegg)
Power Supply: EVGA 850W 80+ Gold Certified Fully-Modular ATX Power Supply  ($95.99 @ NCIX US)
Total: $1905.82
2-3questions:
Should I go with the H110 instead of the H105?
What do you think about the MSI GAMING 9AC?
Why do you guys and other more likely suggsest the Segeta Hard Drive over the WD Black?
2-3questions:
The H105 and H110 are pretty similar in performance, so either is good.
The Gigabyte Sniper is a great gaming board, and it has excellent onboard sound. The MSI is pretty pricey at $259 so unless you need the features then you are overspending.
The WD Black drives are better if you are building a workstation type pc. For a gaming pc then the WD Blue or Seagate Barracuda is fine.
Mmm... Spec wise it's not different from ASUS :P So there may be something Idk about there so try to look up the review of both before you decided
No particular reason. Seagate Barracuda work for me pretty well (I own 2 of them) while being cheaper compare to the WD Black, so I usually go with the Seagate as my default choice
H110 is good too. I like Corsair Link :P X61 is better but if you dont have that option then X61 is ok
As an owner of the 9AC, I would ask you why that board and not the 7, It's a good board and I was going to get the 7 myself but found a great deal on the 9AC, i7 4790K will give you plenty for video editing, the H105 is a good cooler (probably a little overkill, I bought one because it was cheaper than the H100i), if your video editing you may want to look for a good quality IPS panel if your dealing with accurate colour work, a 780 from Evga or MSI would be a good choice, for the PSU have a look at the Evga 750G2, I'd recommend 16Gb of fairly quick RAM (1866+) I would recommend good quality fans (hard to go wrong with Noctua or Be Quiet) Seagate Barracuda is a good drive and an SSD would be a good idea (Samsung EVO 120GB or Crucial MX100 128GB), for the case either the Corsair Air 540 or NZXT H440 would be a good choice. Hope this helps
Intel Core i5 4690K @ 4.2Ghz | Evga GTX 780 Ti SC ACX with backplate | MSI Gaming 9 AC | 8GB (2x4) Corsair Vengeance Pro Silver 2400 MHz | Corsair H105 128GB Crucial MX100 | Toshiba 2TB | Evga 750G2 | Corsair Obsidian 750d | Be Quiet Silent Wings 2 PWM (3x140mm & 3x120mm)
I think Intel Core i5 will fit better. When you will overclock it will be good as Intel Core i7 in gaming, even better sometimes. Go for WD Black series HDD if you want to store games om the HDD and play them. If you want HDD only for storage (music, videos etc) go for Green or Blue. They are more quiet. Samsung 840 PRO Series are better than EVO. If you are playing @1080p I think 780 Ti will be better than 290x, but if you want to play on 4K 290x wins. Good luck, M8!
Better go 1080P @ 144Hz than 4K on 60Hz.
"I am like ninja, but less gay" - Deadpool
thx for the aswer
Thx for the answer
