I recently decided to build a custom PC. Turns out I don't 100%  know everything I need to know about to build a PC. So far I have bought a NZXT Phantom 410 case, and an MSI B85-G41 motherbored. And I have a pretty strict buget at about 1500  USD including the case and mother bored, I wanted to have a triple monitor setup. What do I do??? Someone help me. Thanks.
https://linustechtips.com/topic/212104-first-build/
http://pcpartpicker.com/parts/partlist/
Put your build together in pcpartpicker then post the link than I and other members of the forum will refine it to suit you
http://pcpartpicker.com/p/6BRKnQ There you go thats all I have so far not sure what parts to pick
https://linustechtips.com/topic/212104-first-build/#findComment-2879094
Does that look ok guys? Do all mobos have HR bios till now ye?
CPU: Intel Xeon E3-1231 V3 3.4GHz Quad-Core Processor  ($247.98 @ SuperBiiz)
Motherboard: MSI B85-G41 PC Mate ATX LGA1150 Motherboard  ($79.19 @ Amazon)
Video Card: PowerColor Radeon R9 290 4GB PCS+ Video Card  ($348.50 @ Newegg)
Case: NZXT Phantom 530 (Red) ATX Full Tower Case  ($119.99 @ Amazon)
Monitor: Acer H236HLbid 60Hz 23.0" Monitor  ($139.99 @ Best Buy)
Total: $1502.17
Generated by PCPartPicker 2014-09-09 08:25 EDT-0400
https://linustechtips.com/topic/212104-first-build/#findComment-2879189
Storage: Samsung 840 EVO 120GB 2.5" Solid State Drive  ($86.95 @ OutletPC)
Case: NZXT Phantom 410 (Red) ATX Mid Tower Case  ($84.99 @ Mwave)
Monitor: Dell S2340M 60Hz 23.0" Monitor  ($159.98 @ OutletPC)
Total: $1287.51
Generated by PCPartPicker 2014-09-09 08:27 EDT-0400
If you want to do triple monitor setup in the future consider the Dell S2340M
My current rig for entertainment/gaming: i5 4570 3,2GHz; MSI B85M-E45; ZOTAC GTX760 AMP!; 8GB (2x4GB) by Kingston; Seagate Barracuda 1TB 7200rpm; Corsair 200R, Corsair VS650; Dell U2312HM, Samsung DVD R/W optical drive; CM Devastator; Corsair MM400 gaming pad
https://linustechtips.com/topic/212104-first-build/#findComment-2879198
Total: $1502.17
Would this build work with any GTX Geforce like 660 or above?
https://linustechtips.com/topic/212104-first-build/#findComment-2881631
Here is a build with an Nvidia gpu. (It would be better and still under budget with an R9 290.)
CPU: Intel Core i5-4590 3.3GHz Quad-Core Processor  ($194.99 @ Newegg)
Memory: G.Skill Sniper Series 8GB (2 x 4GB) DDR3-2133 Memory  ($74.70 @ Newegg)
Storage: A-Data Premier Pro SP600 128GB 2.5" Solid State Drive  ($59.99 @ Newegg)
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive  ($53.99 @ Amazon)
Video Card: MSI GeForce GTX 770 2GB TWIN FROZR Video Card  ($302.99 @ SuperBiiz)
Power Supply: SeaSonic 620W 80+ Bronze Certified Fully-Modular ATX Power Supply  ($74.99 @ Newegg)
Operating System: Microsoft Windows 8.1 (OEM) (64-bit)  ($97.98 @ OutletPC)
Monitor: Acer H226HQLbid 60Hz 21.5" Monitor  ($129.99 @ Newegg)
Total: $1413.78
Generated by PCPartPicker 2014-09-09 19:33 EDT-0400
https://linustechtips.com/topic/212104-first-build/#findComment-2883728
