A friend is in need of a graphics card but doesn't want to spend too much. Do you guys know of a card that is better than GeForce 6100 On Board graphics and won't be bottlenecked(Too Much) by a PCIe x16 gen1 slot? Hopefully it can be relatively cheap as well. Under 50 would be great.
https://linustechtips.com/topic/211937-cheapest-okay-card/
What do you want to do with it... What games?
PC: 4770K @ 4.0 GHz --- Maximus VI Hero --- 8 GB 2133 MHz Corsair Vengeance Pro --- EVGA 780 TI Classified @ 1300 MHz --- Samsung Evo 250 GB --- Corsair RM 750 --- Corsair Carbide Air 540 --- CM Storm Rapid-I (MX Blues with PMK Evergreen Keycaps) --- Windows XP --- Razer Naga --- Custom Loop Parts: 380I, EKWB 780 Classy Waterblock and Backplate, 240mm and 360mm XT45, Swiftech MCP655, EKWB multi option reservoir, Mayhems Pastel Red, Primochill Primoflex Advanced Clear Tubing, 5 SP 120 Quiet Editions --- Mobile: Surface Pro 3 (i5 128gb) with JD40 (MX Clears) and Microsoft Sculpt Mouse --- Galaxy S6
https://linustechtips.com/topic/211937-cheapest-okay-card/#findComment-2876724
gtx 750ti or r9 270 is what i would go with for a decent cheapish card really depends on how much they want to spend though
Yes Yes Legalize Gay Marriage sure, but have you ever considered Weaponizing Gay?
CPU: I5 4690 3.5ghz || MOBO: MSI B85-G43 Gaming Board || RAM: 8GB Corsair Vengance Pro - Red || GPU: Gainward GTX770 Phantom 4gb || PSU: EVGA SuperNova 750W Gold || Case: Thermaltake Urban T31 || SSD: Corsair Force 120GB || HDD: 1TB WD Black
https://linustechtips.com/topic/211937-cheapest-okay-card/#findComment-2876743
Maybe a 7770?
CPU: R5 5800X3D Motherboard - MSI X570 Gaming Plus RAM - 32GB Corsair DDR4 GPU - XFX 7900 XTX 4GB Case - NZXT H5 Flow (White) Storage - 2X 4TB Samsung 990 Pro PSU - Corsair RM100E Cooling - Corsair H100i Elite Capellix Keyboard Corsair K70 (Brown Switches)  Mouse - Corsair Nightsword RGB
https://linustechtips.com/topic/211937-cheapest-okay-card/#findComment-2876747
Go with the EVGA GTX 750Ti SC http://www.amazon.com/gp/product/B00IDG3IDO. It should be able to play those games on high settings at that resolution. The 750Ti is also a very low power usage and heat output card which is an added bonus.
Cooler Master HAF XB EVO, ASUS Maximus VII Hero, i7-4790K @ 4.5GHz, Corsair H100i, EVGA GTX 980Ti SC, Corsair Vengeance Pro 2X8GB 1866Mhz CL9, 2X Crucial M500 960GB, EVGA SuperNOVA 1050 GS, ASUS ROG Swift PG278Q w/ nVidia 3D Vision 2
https://linustechtips.com/topic/211937-cheapest-okay-card/#findComment-2876776
I´ve got a GTX 750 Ti in my HTPC with an i5 and this is okay performance. The power consumption is very low and the settings in 1080p med is alright for gaming if you are not too picky about details and AA settings.
Intel i7 7820X (delidded) @ 4.9GHz - MSI X299 M7 ACK + EKWB Fullcover Block - G.Skill Trident Z 32GB @ 3466MHz - nVidia Titan Xp + EKWB Fullcover Block @ 2.1GHz - Samsung 960Pro 2x - WDD Blue 2TB - Seasonic 750W Platinum - modded Corsair 600C - Hardtubed Custom Watercooling
https://linustechtips.com/topic/211937-cheapest-okay-card/#findComment-2876798
CPU: Athlon 64 x2 3800+ Dual Core @ 2.4 GHz
Motherboard: Foxconn AM2 MCP61S
RAM: 1+.5 GB DDR2 @ 800 MHz
Graphics: GeForce 6100 on-board graphics
PSU: 250 Watt -> Not sure what else. It's part of pre-built: http://www.cnet.com/...b-160-gb/specs/
Storage: Two 80GB HDD
Display: Acer P205h
Random Keyboard and Mouse
These are the specifications. He is thinking about adding more RAM as well, to 4 GB DDR2
https://linustechtips.com/topic/211937-cheapest-okay-card/#findComment-2876810
