OS won't load until a reset.
Go to solution Solved by Jodomcfrodo,
I had a similar problem. Something with compatibility settings in the bios. Reset the bios and you're good. (At least I was)
Hi everyone, I built my current computer about 9 months ago and just recently it started having trouble loading into Windows. It gets stuck at a black screen with a text cursor blinking in the top left corner of the screen. The strange thing is that if I simply restart the computer with the reset button, it would boot up fine. Once it boots up everything works normally, there isn't any noticeable difference in temperature or performance or anything. This happened for the first time last Friday and has been happening up to now, so I would say that this is happening consistently. I didn't install anything new before the last Friday or change any configuration. Here's my specs:
Mobo: Gigabyte Z87X-UD3H-CF
CPU: intel i7-4770k
GPU: nvidia GeForce GTX 780
PSU: Corsair RM750 750W
OS Windows 8.1 64 bit
Even though I can use my computer just fine right now I feel like this will probably become a bigger problem if it's not taken care of. Any insight is appreciated.
https://linustechtips.com/topic/211929-os-wont-load-until-a-reset/
PC: 4770K @ 4.0 GHz --- Maximus VI Hero --- 8 GB 2133 MHz Corsair Vengeance Pro --- EVGA 780 TI Classified @ 1300 MHz --- Samsung Evo 250 GB --- Corsair RM 750 --- Corsair Carbide Air 540 --- CM Storm Rapid-I (MX Blues with PMK Evergreen Keycaps) --- Windows XP --- Razer Naga --- Custom Loop Parts: 380I, EKWB 780 Classy Waterblock and Backplate, 240mm and 360mm XT45, Swiftech MCP655, EKWB multi option reservoir, Mayhems Pastel Red, Primochill Primoflex Advanced Clear Tubing, 5 SP 120 Quiet Editions --- Mobile: Surface Pro 3 (i5 128gb) with JD40 (MX Clears) and Microsoft Sculpt Mouse --- Galaxy S6
