YOU SHOULD FIND YOUR CAPS LOCK KEY FIRST
found mine
edit: here you go: http://www.ncix.com/detail/corsair-obsidian-series-800d-full-5a-41960-1360.htm
steam game would be appreciated, my username on steam is "Bloodyvalley" but you don't have to :P
not available anymore
signatures are the illuminati #mkultragotcha
https://linustechtips.com/topic/211246-help-me-find-a-800d/#findComment-2867123
https://linustechtips.com/topic/211246-help-me-find-a-800d/#findComment-2867198
If the 800D is so hard to find AND you're finding them used on eBay, it's probably near or at EOL.
I would look into a 750D or pony up for a 900D.
The 800D design seems a bit dated anyway.
The older cases are of better quality
Intel 3570k 3,4@4,5 1,12v Scythe Mugen 3 gigabyte 770     MSi z77a GD55    corsair vengeance 8 gb  corsair CX600M Bitfenix Outlaw 4 casefans
https://linustechtips.com/topic/211246-help-me-find-a-800d/#findComment-2867516
