None gaming white system build
Requirements:
1. As much white as possible
2. No dedicated GPU integrated will be fine
3. Keep the price as low as possible
4. Case is the define r4 arctic white with window
5. Fully modular psu or one with white cables (if such a thing exists)
This is a build for basic web browsing, documents, and other random average tasks.
Anything helps and thanks you. ;)
https://linustechtips.com/topic/209703-none-gaming-white-system-build/
