Hi all
So I have two drives in my system
One SSD and a HDD
How ever my harddrive which is a 3TB baracuda is not
showing up in the bios or in diskmanger in Windows 7
The hard drive is connected to the Intel chip set on my Asus Maximus VI formula
powered by a Corsair 860 using all stock cables?
I don't think the the drive is dead sue to the fact I can feel it spin on start up
I have tried changing the cables to to see if they were the problem nope
Tried different sata ports nope
What should I do next?
IntelCorei54670k,Maximus VI Formula,Swift tech H220, 16gigs Corsair Dominator platinums, Asus DCUII GTX 780,1x256 840 evo, 1x 2TB Segate barracuda, Corsair AX 860,
3 X Noctua NF-F12, 2x Noctua NF A-14, Ducky Shine 3 Blue Leds Blue switches, Razer Death Adder 2012, Corsair vengence 1400
https://linustechtips.com/topic/209600-hard-drive-issue/
if you have tried different sata data cable, sata power cable and plugin into a different port on the motherboard. then i would say it's a dead HDD :'(
you can always (if you able) try the hdd in another pc or dock to double check.
Win 10 Pro 64bit| Intel i5-4670k| Corsair H100i| ASUS Maximus VI GENE| 2x8GB PC3-14900 Corsair Vengeance Pro Red| MSI GeForce GTX 1070 | SanDisk 240GB Extreme Pro SSD| WD 3TB Red | WD Black 3tb | Corsair Obsidian 350D| Corsair AX760 | Dust |
https://linustechtips.com/topic/209600-hard-drive-issue/#findComment-2844469
Hi all
One SSD and a HDD
Does the HDD show up in the Bios?
https://linustechtips.com/topic/209600-hard-drive-issue/#findComment-2844470
Or in disk manager?
Laptop - Lenovo Y50   Keyboard - Corsair K95 RGB Cherry MX Brown   Mouse - Logitech G502 Proteus Core   Mousepad - Razer Firefly
Please read the LTT Code of Conduct before submitting a post
https://linustechtips.com/topic/209600-hard-drive-issue/#findComment-2844563
Nope
https://linustechtips.com/topic/209600-hard-drive-issue/#findComment-2844592
Or in disk manager?
Nope
Ahh I lack the ability to do that which sucks
https://linustechtips.com/topic/209600-hard-drive-issue/#findComment-2844603
Or in disk manager?
Sadly no
https://linustechtips.com/topic/209600-hard-drive-issue/#findComment-2844605
Sadly no
Unfortunately, I would have to say that your drive is most likely dead. Sorry.
https://linustechtips.com/topic/209600-hard-drive-issue/#findComment-2844748
But it spins :( :( :(
Noooooooooooooooooooooooo
https://linustechtips.com/topic/209600-hard-drive-issue/#findComment-2845150
