Hi everyone i have a crazy colour scheme in my for my build and before i start properly i need to know :
if using Fake carbon fibre looking vinyl sheets (also known as fablon) a gpu backplate or hardrives will i come across any heat problems ?>
im thinking of using them on the back of my case behind motherboard and on backplate of gpu will problems occur if used on these parts?.
thanks for reading and hopefully somebody has a answer me.
Amd fx 8350,asus sabertooth R2,corsair c70,corsair h100i,palit gtx 580,corsair 8gb vengeance Ram,corsair txm 750.
https://linustechtips.com/topic/20743-carbonfibre-sheet-heat-problems/
Apparently heating vinyl can produce toxic gas, but I don't think a computer gets that hot.
I don't think you'll have an issue.
15" MBP TB
AMD 5800X | Gigabyte Aorus Master | EVGA 2060 KO Ultra | Define 7 || Blade Server: Intel 3570k | GD65 | Corsair C70 | 13TB
thanks for the reply blade of grass ,yeah i didnt think it would of been an issue but im new to the whole mod pc scene so thought id ask thanks again tho :)
