hi ive done a dummy kit for water cooling see what people think
ive got;
ek waterblock ek-supreme
xspc single bay reservoir
black ice gt stealth 120 rad
8 1/4" bspp -1/2 id -3/4 od compression fittings
2 1/2" id - 3/4"od xspc clear hose 1m
ek water blocks ek-ekoolant premixed blood red 1000ml
ek waterblock ek-dcp 4.0 pump 800l/h
corsair sickleflow red 120 mm
if i was going to get this are there any faughts with the dummy kit and if so what would you change if buying
2d flow line
purple line out off res into in pump
yellow 1 out of pump to in cpu cooler
yellow 2 out of cpu cooler into rad
brown rad out to res in
https://linustechtips.com/topic/20712-own-watercooling-kit/
Could you please make diagram of your loop? This not only helps us understand what you want but it also helps you to understand what you want better and makes it easy to spot potential flaws in a loop.
To do this simply grab a 2D side on snap of your case. (Just type your case name into google images and scroll down a bit till you find one, it should be there.) Then go to a photo editing program and simply put rectangles where you would like to place your radiators, blocks, reservoirs, pumps and tubing. For blocks use blue, for radiators use red and anything else use grey and for tubing use orange/brown lines with an arrow to point out the intended flow direction of your loop. There is no need to put fans in. This forum has an upload function or you can use an image sharing site and embed the picture into your post. This is an example of this from my personal loop: http://i.imgur.com/MynbfCp.jpg
We can get into the specific parts once you do that.
Also, an ATX bridging tool is a waste of money. It is very very easy to bridge the power supply. Nothing to be afraid of.
Feel free to PM for any water-cooling questions. Check out my profile for more ways to contact me.
Add me to your circles on Google+ here or you can follow me on twitter @deadfire19.
https://linustechtips.com/topic/20712-own-watercooling-kit/#findComment-247616
ive got;
2d flow line
what case?
what system Intel or AMD? overclock?
to be honest, i hate saying this, but the H80 would be better if that is the case layout.
if proceeding with custom loop order would be
res->pump->rad-> CPU->res
cuts down on back-n-forth on hose to create shorter runs.
use a better fan than the sickleflow, spectre pro LED for a better fan at least.
since trying to use a LED, use the Raystorm and the RED led for illumination of CPU block.
airdeano
https://linustechtips.com/topic/20712-own-watercooling-kit/#findComment-249962
what case?
airdeano
yh it ok to get an aio watercooling but its not personised then i want to build and say i built it not i build the system and brought a pre built aio water cooler
https://linustechtips.com/topic/20712-own-watercooling-kit/#findComment-253168
Get a bay res and pump combo and mount the 120mm radiator at the back.
https://linustechtips.com/topic/20712-own-watercooling-kit/#findComment-253376
will a pump res combo with 400l/h be good enough or should i op for a 800l/h pump?
Any Laing pump is fine. Pick laing for the best reliability and performance.
https://linustechtips.com/topic/20712-own-watercooling-kit/#findComment-257231
Its best if you pick the parts yourself rather than using a kit but yes.
https://linustechtips.com/topic/20712-own-watercooling-kit/#findComment-257312
i'd deffo vote against the alphacool res. noisy, can't fill 100%, fill-port is lower than top
and mounting is pish...
i'd opt for the bay reservoir and use a pump/pump top to keep the vibration to a minimum
and remotely mount the pump/pump top. if not, you will not like the racket it makes..
airdeano
https://linustechtips.com/topic/20712-own-watercooling-kit/#findComment-259005
