I have the 770 from Asus and I run the 24" version of the monitor. That being said, games such as Dota 2, counterstrike, and team fortress are easily destroyed played at max at greater than 144 hz except Dota as it is caped at 120. Games such as bf3 and world of tanks at max are not able to run at 144hz as they run more at 70-90. So there's a little background.
I'm a student currently attending the University of Michigan-Ann Arbor, if you attend or around there please don't hesitate to contact me!
Mudkip: CPU: i5-4670k; Cooler: CM Hyper 212 Evo; Memory: 16GBs Corsair Vengeance DDR3 1600MHz; Motherboard: Gigabyte Z97X UD5H; GPU: ASUS DCUII 770 2GB @ 1254MHz; HDD: Seagate Barracude 1TB; PSU: CX750M; Case: ThermalTake A31 Chaser Thunder
https://linustechtips.com/topic/206849-need-help-chosing/#findComment-2806822
