Hey everyone,
     I am looking to buy a Komodo™NV-LE water block for my 780 I have the EVGA supper-clocked w/ their cooler.  The PCB is of reference design to my knowledge but I wanted to confirm this so that I dont end up buying it and having no use for it.
Thank you.
https://linustechtips.com/topic/206333-does-my-water-block-fit/
Hey everyone,
Thank you.
The evga superclocked 780 is a reference pcb so it should fit
OAS || AAS || LLS
https://linustechtips.com/topic/206333-does-my-water-block-fit/#findComment-2800297
"The Komodo-NV LE is compatible with Nvidia reference PCB designs P2083, including GTX Titan, GTX titan Black, GTX 780, and GTX 780 Ti.  The PCB revision number represents the deciding factor to go by when selecting your Swiftech product,rather than the brand and/or model number of the card. Nvidia reference design boards normally bear the Nvidia logo, with the PCB number positioned directly below it.  Please carefully inspect your card to locate the PCB revision number.  "
http://www.swiftech.com/KOMODO-NV-LE.aspx#tab3
Also known to his peers as Lord Scrubby McScrubington
https://linustechtips.com/topic/206333-does-my-water-block-fit/#findComment-2800315
