I'm thinking of getting a laptop used on eBay for less than $400. My two main competitors are the lenovo ThinkPad T410, and ThinkPad W510. I really need dedicated graphics and the eBay listing for the w510 isn't specific on which graphics type it has. Do all w510's have fx 880m's? What is the 880m like, compared to the NVS 3100m in the T410? The w510 is $50 more. Is it with it? I also can't figure out the resolution on the W510. It's a bigger display, so does it have higher res?
Any help is much appreciated.
ThinkPad W510 $350:
http://pages.ebay.com/link/?nav=item.view&id=251627771975&alt=web
ThinkPad T410 $300
http://pages.ebay.com/link/?nav=item.view&id=251624607656&alt=web
https://linustechtips.com/topic/204948-laptop-help/
I currently own the T410. It's good enough for taking notes and watching videos but if I wanna do anything that uses any power it struggles, and I'm willing to be the W510 wouldn't be much better. Those are first hen i7s in both systems. The 3100m is nothing to speak of. Can't do any kind of gaming. On the other hand it's awesome for school just because it has a bunch of different ports and a little keyboard light ;)
The w510 doesn't have an 880m. it has some sort of quadro variant or a low power GTX.
Between these two i would say do the W510. But see if you can save up a couple hundred more to get a generation or two newer lenovo.
CPU - Intel Core i7 3770K @ 4.60GHz 1.264v | RAM - Corsair Dominator Platinum 16.0GB (2x8GB) | Motherboard - ASUS P8Z77 WS | Graphics - EVGA NVIDIA GeForce GTX 960 | Storage -  120 GB Samsung 840 EVO | PSU - Corsair RM650 | Case - Corsair 550D
https://linustechtips.com/topic/204948-laptop-help/#findComment-2782508
@xNeon thanks! I currently have an IBM ThinkPad X41 Tablet running Windows 8 Pro and pretty much anything is an upgrade. Is there any laptop in particular you would suggest?
hmm whats the most you would be able to shell out?
https://linustechtips.com/topic/204948-laptop-help/#findComment-2782565
Those generally aren't adjectives that come with a $400 lappy, what are you gonna use it for?
https://linustechtips.com/topic/204948-laptop-help/#findComment-2782619
The T series is good, but they can't game at all. Anything with a graphics card that can pull 40fps on low settings will be like $600+
T420
http://www.ebay.com/itm/Lenovo-Thinkpad-T420-Core-i7-2-7GHz-8GB-320GB-HDD-WIN-7-HP-/301291587613?pt=Laptops_Nov05&hash=item462660c81d
w520
http://www.ebay.com/itm/Lenovo-Thinkpad-W520-i7-2720QM-Quad-Core-2-2GHz-4Gb-160Gb-SSD-Quadro-1000M-82b-/380981217919?pt=Laptops_Nov05&hash=item58b4400a7f
Plus you can chuck it off a building and it'll work.
My aunt spilled a full glass of wine on her t430 and it survived no issues.
https://linustechtips.com/topic/204948-laptop-help/#findComment-2782688
W510 if you don't mind the weight. I personally have a T410 and I love it, it boots fast, and it can run older games that I like to play, others I play on my desktop
Lenovo ThinkPad T410 || i5-520M || 4GB RAM || 256 GB SSD + 320GB Ultrabay || Windows 8.1 Update
Asus Nexus 7 2013 || Android 4.4.4 Rooted
Nokia Lumia 920 || 32 GB || Windows Phone 8.1 Update + Nokia Cyan
https://linustechtips.com/topic/204948-laptop-help/#findComment-2785817
