Looking into water cooling and want to know if I would be able to mount a h80i in my case (Sharkoon T28)
I will be sacrificing air flow for sure and will have to rely on ambient air flow
Am I right to mount it here?
Desktop:  MSi GTX 680 Lightning - MSi Mpower Z77- i7 3770k - Asus Xonar DGX  - 16Gb Ares Ram - GX 750w PSU
Laptop: MSi GE 60 - GTX 765m - i74700MQ - 8gb ram
https://linustechtips.com/topic/20472-help-a-watercooling-noob/
The H80i is a 120mm watercooler, so if a 1200mm fan can fit there then the H80i should fit there no problem. As for sacrificing airflow... That depends on where you have your intake fans and where you have your exhaust fans.
https://linustechtips.com/topic/20472-help-a-watercooling-noob/#findComment-244046
Should fit
CPU: Intel i5 3570k 4.2GHz with Corsair H100 RAM: Corsair 16GB (4x4) SSD: Samsung 840 120GB HDD: Seagate Barracuda 1TB GPU: Strix GTX 1080
PSU: OCZ 650W CASE: Fractal Define R5
https://pcpartpicker.com/user/MelchiorVester/saved/#view=RKNXsY
https://linustechtips.com/topic/20472-help-a-watercooling-noob/#findComment-244069
I think I will go for it. Water-cooling seems like the way to go especially if I want to start over-clocking further.
https://linustechtips.com/topic/20472-help-a-watercooling-noob/#findComment-248875
