Hard drive partitioning problem
Go to solution Solved by Accidentx13,
Not to seem like an arse, but http://support.microsoft.com/kb/300415 Only way your going to learn :) As when you self learn you can teach those from your mistakes e.t.c. Good luck dude
How can I get backup to show up as one big square and shrinking and re-extending doesnt work also it wont let me extend the C partition with the unallocated space if I shrink
I know the backup should be on a separate drive shut up about it (its mainly backup from my rabid deletion habits)
and what is this system reserved thing
https://linustechtips.com/topic/202496-hard-drive-partitioning-problem/
Disk part from CMD. Google the commands to assist you further :)
exactly what commands am I looking for
also: im heading off to sleep now
