Need Help Picking Power Supply
Go to solution Solved by alby800,
i dont know what brand it was i think it was a 80+ bronze power supply and it was one from my old budget build that i threw out 3 years ago
EDIT: and i think it was a 850W power supply
ok then, try getting a 1000 watt 80+ gold power suppy then I guess
im trying to find a corsair powersupply for my next build BUT i dont know the wattage that is required to power my system (also another question is that if i buy a 1500 W Powersupply will it fry my components) but im getting mixed messages everyone said that the 780Ti needed different wattages that was required to run one card but im getting two so here are ALL of my components + perifirals this will be long
NZXT Phantom 820 Case
ASUS Rampage IV Black Edition + Assassin's Creed 4 Mobo
Intel Core i7 4960K Extreme Edition Processer
G.Skill Ripjaws Z 64GB DDR3  (i do massive projects that render in 8K and i have to downscale to 1080P or 4K)
Seagate Barracuda 4TB (those massive projects)
Samsung 840 Pro Series 512GB SSD (no raid)
Sapphire Radeon R9 290X Tri-X OC 4GB
LG CH12NS30 12X BD-R  Blu-Ray DVD Combo Drive
Artic Silver 5
Windows 8,1
NZXT Kraken X61 280MM AIO Liquid Cooler
Avara TS743 Triple Monitor Stand
Noctua Industrial Fans
3 Monitors
Perifirals:
ROCAT Apuri Mouse Bungee + 4 Port USB Hub
Blue BabyBottle
Scarlet 2i2
Razer Vespula Mouse Mat
Astro A40
Razer Black Widow 2014
Saitek Cyborg Mad Catz M.O.U.S 9
Know that this is overkill but i really need the power for gaming, 4K rendering & much much much much more so yeah soooo i need the help that i can get also i have never built a PC but it seems quite basic, plug thing into thing and repeat for a while and its done ( i know that its harder than that but give me a break) well thanks for the help in advance, best answer gets a cake im looking for how much power i need I NEED THE POWA!!!!!!!!!!!! 1000 1200 1100 1500
https://linustechtips.com/topic/201806-need-help-picking-power-supply/
Wait for X99, and for a single 290x you shouldn't need any more than 650 Watts I think
CPU: Intel Core i5 4460 | GPU: XFX r9 280x DD BLACK OC EDITION | RAM: 8gb Kingston HyperX Fury 1600Mhz | Mobo: Gigabyte h97n-WIFI | PSU: EVGA 600B | Case: Cooler Master Elite 120 | Cooler: Stock intel | SSD: Samsung 840 EVO 120gb | Storage: WD 150 gb
CPU: Intel Core i7 4710MQ | GPU: NVIDIA Geforce GTX 850M | RAM: 8gb Corsair 1600Mhz | Mobo: Metabox WA50SJ Motherboard | Case: Metabox WA50SJ case | Cooler: Stock | SSD: Sandisk 256gb
:wub:  :wub:  :wub:
Best purchase this year, bcuz forza
850-1000W should be enough. And going overboard isn't really a problem.
If you really want to just stick with Corsair, an AXi or HXi (These ones actually out yet?) would be best. A little expensive, but if I recall correctly a 4960X is around 1k, so a little expensive doesn't seem to be an issue.
Personally I'd stick with the most popular recommendation right now, one of EVGA's G2 line.
Also, X99 is expected within the next month if I recall correctly.
INTEL CORE i5-7600K | ASUS ROG STRIX B250i GAMING | CRUCIAL BALLISTIX SPORT LT 16GB | EVGA GTX 970 SC | EVGA B3 550W
SAMSUNG 850 EVO 250GB | CRYORIG M9i | BE QUIET! PURE WINGS 2| FRACTAL DESIGN DEFINE NANO S
im having two 290X's because im having a 3 monitor setup... and i think that its going to be 3 years untill the 299 series comes out
Evga 850g2
oh, it doesn't say that in the op, in that case I would go for a 850 watt at least, although I would go for 1000 watts just to be safe for overclocking and future upgrades.
What is 299? the X99 platform will be replcing the X79 platform and the extreme edition will be an 8 core, 16 threads overclockerbable beast! That should be coming out in a month or 2 I think. Msi and Gigabyte (I think it is them) have been releasing pics for there new mobos so they shouldn't be too long
:wub:  :wub:  :wub:
ok thanks, i checked and its going to come out in a few days (9 or so) i have good uses for the processer, dont you worry about that and the G2 isnt enough to power the cards and the rest of the system (pc part picker and alot of other websites says that all the parts consume around 1200 watts of power
dont get astro a40s, go to tha audio sub form and ask arround what you should get, and maybe wait for x99 and the 59xxk
My Rig
PCPartPicker part list: http://ca.pcpartpicker.com/p/kGNksY
CPU: Intel Core i7-4770 3.4GHz Quad-Core Processor  ($379.00 @ shopRBC)
CPU Cooler: RAIJINTEK THEMIS 65.7 CFM Sleeve Bearing CPU Cooler  ($34.99 @ NCIX)
Motherboard: MSI CSM-H87M-G43 Micro ATX LGA1150 Motherboard  ($78.83 @ DirectCanada)
Memory: Kingston HyperX 16GB (4 x 4GB) DDR3-1600 Memory  ($139.99 @ Memory Express)
Storage: Kingston Fury 120GB 2.5" Solid State Drive  ($71.34 @ DirectCanada)
Storage: Seagate Barracuda 2TB 3.5" 7200RPM Internal Hard Drive  ($92.95 @ Vuugo)
Video Card: Gigabyte Radeon R9 280X 3GB Video Card  ($298.98 @ Newegg Canada)
Case: Fractal Design Define R4 w/Window (Black Pearl) ATX Mid Tower Case  ($125.98 @ Newegg Canada)
Power Supply: Corsair CX 600W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($66.99 @ NCIX)
Operating System: Microsoft Windows 8.1 - 64-bit (OEM) (64-bit)  ($116.00 @ shopRBC)
Case Fan: Cougar Turbine 120 (4-Pack) 60.4 CFM 120mm  Fans  ($23.99 @ NCIX)
Monitor: HP 22xi 60Hz 21.5" Monitor  ($187.11 @ Amazon Canada)
Keyboard: Logitech G710 Wired Gaming Keyboard  ($114.99 @ NCIX)
Mouse: Razer DeathAdder 2013 Wired Optical Mouse  ($76.99 @ Amazon Canada)
Headphones: Kingston HyperX Cloud Pro Headset  ($78.98 @ DirectCanada)
Total: $2074.22
Prices include shipping, taxes, and discounts when availableGenerated by PCPartPicker 2015-04-10 15:33 EDT-0400Build log http://linustechtips.com/main/topic/303263-the-dell-from-hell/#entry4121100
Phone Compassion Spreadsheet https://docs.google.com/spreadsheets/d/1EN6s426gyxqPloIqT4wQ7Y7yovkkQy_5B3djVN-N-R8/edit#gid=0
Gta V Pc Online Crew http://linustechtips.com/main/topic/344773-unofficial-linus-tech-tips-gta-v-crew-pc/
my entire system is based around the haswell and the X79 platforms and im really not going to rebuild my system just because the new platform released and the 299 is a typo my palm must of mashed the 2 button
Wait, have you already built this?
Edit- And X79 is not even haswell, it is ivy-bridge E I believe, X99  is Haswell E
:wub:  :wub:  :wub:
Edit- And X79 is not haswell, it is ivy-bridge E I believe, X99  is Haswell E
yes i have built this and the things not booting up and i tryed a larger powersupply and it worked but the power supply was a old piece of shit
EDIT: then the bloody ivy-bridge-e infastructure!
Edited by G510Gamer
Ohhhh, my bad. I thought you were just planning this. What power supply have you tried?
Sorry for me being a stuppid
:wub:  :wub:  :wub:
What PSU is it? Possibly a DOA PSU.
PC: 4770K @ 4.0 GHz --- Maximus VI Hero --- 8 GB 2133 MHz Corsair Vengeance Pro --- EVGA 780 TI Classified @ 1300 MHz --- Samsung Evo 250 GB --- Corsair RM 750 --- Corsair Carbide Air 540 --- CM Storm Rapid-I (MX Blues with PMK Evergreen Keycaps) --- Windows XP --- Razer Naga --- Custom Loop Parts: 380I, EKWB 780 Classy Waterblock and Backplate, 240mm and 360mm XT45, Swiftech MCP655, EKWB multi option reservoir, Mayhems Pastel Red, Primochill Primoflex Advanced Clear Tubing, 5 SP 120 Quiet Editions --- Mobile: Surface Pro 3 (i5 128gb) with JD40 (MX Clears) and Microsoft Sculpt Mouse --- Galaxy S6
After far too much time on PCPartPicker putting this build together, I can say I find it to be far too finicky.
But more importantly, an EVGA SuperNOVA 1300W G2 or a Corsair AXi 1200W PSU will be what you need. Feel free to go overboard, you shouldn't have any issues.
your forgiven and i threw out the power supply shortly after it blew up in my computer
IT BLEW UP YOUR COMPUTER!!!!!!???????!?!?!?!?!
:wub:  :wub:  :wub:
^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ look up already
What's that supposed to mean ...?
