Hi there :-)
This is the specifications of my server.
CPU: AMD FX-6300 3.5GHz Socket AM3+
Motherboard:Gigabyte GA-78LMT-S2P
Ram: Crucial 8GB DDR3 1333MHz Ballistix Sport Memory
SSD : Crucial v4 32GB SATA 3GB 2.5 SSD
I found out that the raid controller of my motherboard did not support 3tb raid 1. So i bought a High Point RocketRaid 1740. This supports the array and if i configure it and format it it shows up in windows. But after about 2 minuets of copying files to the array the beeper on the card goes off and the logs say.
  error.gif 2014/8/19 15:30:7 Disk 'ST3000DM001-1ER166-Z5005W3J' at Controller1-Channel1 failed. error.gif 2014/8/19 15:29:59
Disk 'ST3000DM001-1ER166-Z5005W0H' at Controller1-Channel2 failed.
If i click refresh on the web gui it works but then it happens again.
Thanks
Iain
https://linustechtips.com/topic/200369-what-is-wrong-with-my-raid/
Have you checked to see if the drives are healthy on their own? i.e. not on the RAID controller?
† Christian Member †
For my pertinent links to guides, reviews, and anything similar, go here, and look under the spoiler labeled such. A brief history of Unix and it's relation to OS X by Builder.
I had them running fine on my own pc.
They may have a slow spin-up time, which is causing the RAID controller to say they have failed. I would check the specifications for maximum spin-up time on the RAID controller and the spin-up time for your drives.
