I noticed that the GIGABYTE Z97N-WIFI has two LAN ports on the rear I/O. I read somewhere that you use both ports at the same time for increased bandwidth, that allows you do multiple things on your network at the same time, such as streaming video and uploading files to a home server, without loosing speed.
I then saw something about pairing the two ports so they work as one unit. Does this mean you get double the internet speed? Let's say i download with 5 mb/s, will my speed then increase to 10 mb/s if i plug in a second cable?
Thanks in advance
#LinusKitchenTips /// "Better than useless" - Linus Sebastian
LTT Holy bible: Code Of Conduct
Project Toaster [My Silver NCASE M1 V2 Build-log]
Main Rig
 Case: Fractal Design Define R5 CPU: INTEL
i5 3570k Cooler: CM Hyper 212 Evo Mobo: Maximus V Gene Z77 GPU: Gigabyte GTX 970 G1 Gaming (w/ 0% fan mode) RAM: Corsair Dominator Platinum 2x8GB 1600mHz Storage: OCZ VERTEX 4 256GB PSU: Corsair AX860 Monitor: ASUS PB278Q 1440p 27" Headphones: QPAD QH-90 Laptop
Macbook Pro Retina 13" i5 256Gb Early 2015
Phone
Oneplus One 64GB Sandstone Black
https://linustechtips.com/topic/200175-dual-lan-how-does-it-work/
This does not affect Internet speed. Your router or switch needs to support link aggregation or teaming. You can have the other port connected to your laptop or another computer for bridged mode.
But if my router supported "teaming" would my theory be correct?
Main Rig
Phone
