Cheap ones are a  bit naff
Logitech attack 3?
Get something from Logitech 'nuff said.. ;)
 [spoiler=CORMAC]CPU:Intel celeron 1.6ghz RAM:Kingston 400mhz 1.99gb MOBO:MSI G31TM-P21 GPU:Will add one later on! CASE:local ROUTER D-Link 2750U, D-LINK 2730U MOUSE:HP,DELL,ViP KEYBOARD: v7 SPEAKERS:Creative 245  MONITOR:AOC E970Sw HEADSET: Sony MDRx05s UPS:conex ups avr 500va PSU:idk OD:Samsung super writemaster STORAGE:80 gb seagate+ Seagate 1TB OS:Windows xp sp3 themed to Windows 7 + Linux |Rest all pc in my house will be updated from time-time
COMING SOON
So what you guys are saying that there is no point of buying the cheaper ones and without 100$ i won't get any descent joystick?
Well, there is always option of a used one.
You see, cheap ones are like a lottery, you can brake it in a year... a month.... or a week. I've had the cheap cyborg v3 gamepad broken in 3 weeks of inactive play. Then got the logitech f710.
The point is - don't buy cheap hardware. Penny wise and pound foolish, eh?
So better pile up some 100 bucks and get a decent one.
I had luck with buying cheaper pc components and they would last longer and work faster when tweaked a bit then the more expensive ones *amd vs intel*. ​I've never had an equipment like this so my knowledge about them is almost none existent. I guess i will have to up my budget a bit and go with 3d extreme pro like my friend suggested unless there are something similar but better then that.
