Custom Firmware?
Go to solution Solved by Vacsol,
I currently have a rooted Samsung Galaxy Note 2. I have been told about custom firmware but i'm not too confident. Any advice and or preferences?
you mean custom ROMs?
Before you flash any ROMs, be sure to understand any risks involved, such as the possibility of bricking your phone and ending up with a Samsung Galaxy Paperweight.
I currently have a rooted Samsung Galaxy Note 2. I have been told about custom roms but i'm not too confident. Any advice and or preferences?
CPU: I7-4790k CPU Cooler: NZXT Kraken X61 Motherboard: Gigabyte GA Z97X-Gaming 3
Ram: Kingston HyperX Fury Black 1866 16GB, (2x8GB) GPU: Gigabyte Geforce G1 Gaming 980Ti
Case: NZXT Noctis 450 (Black/Red) Storage: Samsung 850 Evo 250GB SSD, Seagate Barracude 7200RPM 3TB
PSU: Seasonic 750W 80+ Gold
https://linustechtips.com/topic/199599-custom-firmware/
INTEL CORE I5 4670K | NVIDIA GTX 980 | NOCTUA NH-L9i | GIGABYTE GA-Z97X-SLI | KINGSTON 120GB V300
CM STORM QUICKFIRE TK | BENQ XL2420TE | ROCCAT SAVU | FRACTAL DEFINE R4
https://linustechtips.com/topic/199599-custom-firmware/#findComment-2705806
XDAdevelopers has a huge community of Android enthusiasts who would love to help.
Yeah, Roms is what i meant, Ill edit that.
Thanks for the reference and ill be sure to check it out aswell as the risks.
https://linustechtips.com/topic/199599-custom-firmware/#findComment-2705812
I would recommend cyanogenmod. It's a well known custom firmware that is very well documented and typically not too difficult to install.
http://wiki.cyanogenmod.org/w/Devices#searchable=%22note%202%22
alternatively you could use their new 'installer' if you are really uncomfortable about doing it yourself.
http://beta.download.cyanogenmod.org/install
https://linustechtips.com/topic/199599-custom-firmware/#findComment-2705904
