Upgrade for custom loop
Go to solution Solved by tek inpektor,
I want 1 280mm radiator and another 360 radiator. I would like a mid tower atx. about 100-150 buck. Black. Yes. Prefered
NZXT H440 looks like your best choice.
Soooooooooo........ how many rads do you want? What size? What will your budget be? What is your preferred case color? Do you like side-panel windows? Do you like silent cases?
https://linustechtips.com/topic/198408-upgrade-for-custom-loop/#findComment-2690202
lol my dad is helping me out a lot
With 2 780tis and such, thought you had cash to blow, lol.
I guess any decent full/mid tower would do
http://pcpartpicker.com/parts/case/#t=4,3&s=1&u=1&sort=d5&m=169,50,11,106,62,94,229,63,56
 with the price...
https://linustechtips.com/topic/198408-upgrade-for-custom-loop/#findComment-2690223
