I uninstalled a program that I just chose to put on my desktop and when I went to uninstall it it deleted everything in the directory and itself. So now I don't have any of my files that I had on my desktop and the desktop is gone from my file explorer. Is there a way I can undo this?
https://linustechtips.com/topic/195906-uninstallation-fail-help/
Go to C -> Users -> Home
Create a Desktop folder (if there isn't any)
See if that works.
Try System restore.
If that doesn't work,make a new user on another Windows machine and copy the Desktop folder onto an USB drive and back onto your machine.
https://linustechtips.com/topic/195906-uninstallation-fail-help/#findComment-2657152
Download file recovery software
Planned I Hope Someday I Do First Build: CPU: Intel Core i7 5820k CPU Cooler: CM Hyper 212 EVO Mobo: MSI X99S SLI PLUS RAM: Corsair Vengeance LPX 16GB (4x4GB) DDR4-2133Mhz Storage: Corsair Force LS 240GB SSD & 2TB WD Green Graphics Card: ASUS GTX 970 4GB Turbo Case: NZXT S340 White PSU: EVGA SuperNOVA NEX 750W 80+ OS: Windows 8.1 64-bit OEM Monitor: AOC i2267Fw 60Hz 22" Monitor
https://linustechtips.com/topic/195906-uninstallation-fail-help/#findComment-2657159
