Pre-built PC plan
Solved by PokémonTrainerFour,
There are 2 PCs on Aria.co.uk that I found pretty desirable. The only caveat is that, as far as I can tell, the graphics cards are running stock, which is kinda bad. Still impressive spec.
I would personally choose the 8350 because it has a 290, but the 280X isn't a slouch with the 4690K. You would be surprised what you can squeeze out of the 8350.
