Hi, i was wondering, whats the difference between the normal mpower by MSi and the mpower-MAX? How many features am i loosing by going cheaper with the mpower instead of the max, will i still have sli support?
Thanks,
~Elias
Main PC: Core i5 4670 | MSI Mpower Max z87 | G.Skill Ripjaws 2x4gb | Stock intel cooler | PNY GTX 770 2gb (hoping to upgrade) | Seagate 1tb 7200rpm | Corsair RM850 | Corsair Carbide Air 540 | PCCG custom sleeved black/yellow extensions | Corsair K70 Cherry MX Blue | Corsair M45 |
Phone: LG Nexus 5 | Headphones: Audio Technica ATH-PDG1, Shure SRH440 | Laptop: Asus 303la (i5 model, 1600x900 res) | Motorbikes: 2004 Sherco 290i, 2013 Husqvarna CR125 | Xbox one
You're talking about the Z87 motherboards right?
MPower Max has more phases in its power design than the MPower ( 20 vs 16 phases ), plus 2*8pin cpu power header instead of 1, so it'll give out better results if you want to do some extreme overclocking. Beside that main difference, Max version also has more usb3 ports ( using NEC's usb3.0 controller ) and a TPM header. That's all. Other features are identical between the 2 boards.
Shot through the heart and you're to blame, 30fps and i'll pirate your game - Bon Jovi
Take me down to the console city where the games are blurry and the frames are thirty - Guns N' Roses
Arguing with religious people is like explaining to your mother that online games can't be paused...
Mpower max has 5 phases not 20. The Z87 mpower/ has 8 phases. Physical count or the marketing count means nothing, it's all about how many phases the pwm IC has not about the chokecount. The max is 8 anyways, there's no pwm chip that has more than 8 phases isn't vdr12.5 certified yet either. Mpower is better than the max but it will never show itself doing better even for LN2.
UIawRb8.jpg?1
rvgHTbO.jpg?1
Didnt you read what I said? There is no 16 phase pwm. Do you even realize how they achieve "16 phase"? Using doublers? What do doublers do? Doing nothing besides spreading the load over more mosfets therefore spreading the temps across more mosfets so its easier to cool. A doubler splits a phase in two channels or 4 (4 is the case for the mpower max), with old pwm's you need for each voltage a channel thats why most low-end boards use them. For world record overclocking all that matters is the pwm phase count, digital and mosfet quality. Like I said the choke count or the physical count or the marketingscount means nothing performance wise. Doublers do nothing to your vrm's performance
This is the currently the best PWM IC with the most phases:
