When playing games such as tf2 or minecraft or even bf3 i get an issue with my keyboard. The W key or any other key in the WASD area stops working as i press it as long as I'm holding W or S while I use it. It's getting annoying. Anyone know a way to fix it? This keyboard was given to me by a friend and was literally brand new from the box.
Eric S. Raymond used an E6600 from 2005 until 12/30/14 or open source software creation. Raw data computations in excess of 18GB each. Core 2 Duos still have tons of life left, my friend.
https://linustechtips.com/topic/186323-microsoft-wireless-keyboard-1000-problem/
Restart Computer. If that does not work RMA the Keyboard.
Rig CPU Intel i5 3570K at 4.2 GHz - MB MSI Z77A-GD55 - RAM Kingston 8GB 1600 mhz - GPU XFX 7870 Double D - Keyboard Logitech G710+
Case Corsair 600T - Storage Intel 330 120GB, WD Blue 1TB - CPU Cooler Noctua NH-D14 - Displays Dell U2312HM, Asus VS228, Acer AL1715
well i kept trying and i discovered that it only happens when i move the mouse. must be the receiver being stupid.
if they are using the same 2.4GHz frequency
yes it could be interference
Budget? Uses? Currency? Location? Operating System? Peripherals? Monitor? Use PCPartPicker wherever possible.
Quote whom you're replying to, and set option to follow your topics. Or Else we can't see your reply.
likely I will admit. It only stops typing when i move the mouse. When I'm playing a game and i move the mouse to move my character, the character stops moving.
Like...
wwwwwwwwwwwwwwwwwwwwwwww (this is where i moved the mouse)
replaced all the batteries and installed microsoft's latest drivers.
