I just bought this monitor today, and it seemed like a very good buy at the time. It is IPS and 1080p, I am upgrading from 1680x1050 so I thought this would be a great upgrade. So far this monitor has been terrible, the screen when set to 1920x1080 has a 1 inch gap between the Bessel and where the pixels cut off. I am running dual monitors with my old one and I tried disconnecting it to see if that was the cause, that did nothing. the only way I can get it to go full screen is if I lower the resolution to 1680x1050 which defeats the only reason of having it. I wanted to ask here before I go and return it, I couldn't find many reviews on this monitor to begin with but the ones I did find people said it was fine.
Is it just a problem with mine, or is it just a bad monitor? I bought it for $174 so if I am returning it it would be great if you could suggest a monitor that is good for the same price.
Current system CPU: Intel 4670k    MotherBoard: Asus z87-C   RAM: 12GB 1333mhz GPU: Sapphire AMD r9 290    Case: Corsair 200R    Storage: 250gb Sandisk SSD, 1tb segate barracuda HDD PSU: Corsair RM 850 Cooling: Corsair h100i No over clock
https://linustechtips.com/topic/185818-aoc-2367fh-problems/
I own the DVI/VGA model of this monitor, the non-h. The issue you are having sounds like one with the monitor or interface, since with both of my monitors, they work just fine.
Are you sure the bezel is 1 inch? Did you measure, or are you making an educated guess?  In reality, the monitor has an around 12mm bezel.
It is a very good monitor, but you may have just gotten a dud.
If you decide to return it and leave AOC as a brand, you can be certain in buying the Acer H236hlbid
https://linustechtips.com/topic/185818-aoc-2367fh-problems/#findComment-2498882
here is a picture, its the one on the left.
post-7483-0-53153900-1406164782_thumb.jp
https://linustechtips.com/topic/185818-aoc-2367fh-problems/#findComment-2498899
Yeah. that's not normal.
You can try a different display cable, display input and different graphics device altogether.
If all else fails, try returning it and picking up the aforementioned Acer monitor.
https://linustechtips.com/topic/185818-aoc-2367fh-problems/#findComment-2498936
