My microphone/computer is producing a strange electronic noise/static and I can't seem to find a solution, so I've come to you guys for help.
When plugged in via 3.5mm jack I get a very loud electronic noise that reacts to computer activity such as mouse movement. This noise percists regardless of if the microphone is muted or even unplugged, so I believe the problem to be computer related not microphone related.
When plugged into an external sound card I still get excessive static/noise, however it doesn't seem to react to computer activity.
Example 1, Astro Mixamp: http://clyp.it/2uxxb4uo
Example 2, SteelSeries USB Sound Card: http://clyp.it/4mojkyg0 (Note: this card seemed to react to being touched [0:06])
I've tried different headsets, different outlets, with and without power bricks, every computer setting imaginable and even different houses! however the problem percists...
Relevant PC Specs:
Motherboard: MSI Z77A-GD65
Power Supply: OCZ ZT Series 750W
Headset: Senhieser pc360
I'm currently using my headset through the Astro mixamp since the static is most bearable.
Would a dedicated PCIe sound card solve my problem? If so, which would you reccomend?
Any help at all would be greatly appreciated! I've been dealing with this issue for over a year and really want to get this sorted out. If you need any more info don't be affraid to ask. Thanks for reading. :)
https://linustechtips.com/topic/185238-electric-noise-microphone-static/
You're not having the same problem across devices, you're having multiple occurrences of similar issues across different devices.
The first one is either bad case grounding, or just a junky motherboard in general. Second is just louder than average backgroundg static, and third is another junky solution.
Try different USB ports and if that doesn't help then grab a syba dac/amp and that should fix it.
I've tried multiple USB ports (front and back) but all had the same problem. I'll look into the syba dac/amp, but since they're connected by USB wouldn't I have the same problem? Thanks for the advice :)
I can see how they each sound different, but thought that maybe they were all caused by the same rout problem such as a faulty power supply or motherboard. Both my external sound cards produce a clear signal on other computers, so I don't believe they are the problem. Thank you for the help :)
Well then maybe you are right. I assumed different house meant different computers.  :unsure:
Faulty PSU, mobo or simply bad case grounding would cause things like this.
Oh if the sound cards sound fine on other computers I would guess that it might be your mobo's fault. But the other things ShearMe said might be it too.
I see. So does this mean the best solution is to try replacing the motherboard and PSU, and how would I go about fixing "bad case grounding"? Do you think a dedicated sound card would resolve these issues? I would rather not go through the hassle of replacing the PSU and motherboard if it can be avoided. Once again, thanks for the help. :)
