Hey, this is my first time building a custom loop. I want to cool my processor (i7 3770k) and graphics card(Zotac gtx 770 4gb edition). My case is a corsair 300r. I need help finding the right reservoir, pump, gpu water block, cpu water block, tubing, fluids, etc. Any help would be greatly appreciated. Thanks!
Links to processor and GPU if needed.
Processor: http://www.newegg.com/Product/Product.aspx?Item=N82E16819116501&cm_re=i7_3770k-_-19-116-501-_-Product
GPU: http://www.newegg.com/Product/Product.aspx?Item=N82E16814500303&cm_re=zotac_770-_-14-500-303-_-Product
https://linustechtips.com/topic/183847-water-cooling-help/
Budget?
Location?
Colored tubing or liquid?
Bay or tube reservoir?
Tubing size preferences?
I'll get a list going once I know those things!  :)
PC: 4770K @ 4.0 GHz --- Maximus VI Hero --- 8 GB 2133 MHz Corsair Vengeance Pro --- EVGA 780 TI Classified @ 1300 MHz --- Samsung Evo 250 GB --- Corsair RM 750 --- Corsair Carbide Air 540 --- CM Storm Rapid-I (MX Blues with PMK Evergreen Keycaps) --- Windows XP --- Razer Naga --- Custom Loop Parts: 380I, EKWB 780 Classy Waterblock and Backplate, 240mm and 360mm XT45, Swiftech MCP655, EKWB multi option reservoir, Mayhems Pastel Red, Primochill Primoflex Advanced Clear Tubing, 5 SP 120 Quiet Editions --- Mobile: Surface Pro 3 (i5 128gb) with JD40 (MX Clears) and Microsoft Sculpt Mouse --- Galaxy S6
https://linustechtips.com/topic/183847-water-cooling-help/#findComment-2470586
Budget?
Location?
400 max but if it can be cheaper 300 would be perfect.
colored tubing
no preference for tubing size.
Sorry if i missed anything like i said this is my first time
https://linustechtips.com/topic/183847-water-cooling-help/#findComment-2470626
colored tubing
Location as in country lol. I've made that mistake too.  :)
https://linustechtips.com/topic/183847-water-cooling-help/#findComment-2470654
United States lol
Ok. I'll try to fit that budget, but it might be tough.
I made a post over here: http://linustechtips.com/main/topic/183831-help-water-cooling-my-system/#entry2470664
 The list over there will help you.
https://linustechtips.com/topic/183847-water-cooling-help/#findComment-2470690
I can follow the list you made over there but could you help me find a waterblock for my GPU... I have been searching all night and im very confused.
Most of the other stuff is pretty straight forward. Im just having trouble finding the right water block
https://linustechtips.com/topic/183847-water-cooling-help/#findComment-2470696
Do you know if the PCB is reference?
https://linustechtips.com/topic/183847-water-cooling-help/#findComment-2470711
