I have anywhere between 40 and 60 hard drives which I took from old servers which all need the data wiped from them.
I don't plan to do any mass formats at once and realise it could take some time, but I currently have a spare computer which has space for up to 3 drives at a time (+1 for the OS) and I thought I would just be able to plug the SATA drives into the HDD bay and clear the data in the OS, but for some reason I cannot load into the OS and Windows 8 brings up it's sad face emoticon, reboots and repeats the same error.
Am I not doing it correctly? If not, what would be a better way to clear the data of these drives without having to go out and buy something like an enclosure -  or is that my only option?
Computer Specs (The Space Fridge):
CPU: Intel i5 3570k | Motherboard: MSI Z77A G45 | RAM: Kingston Hyper X Blu | SSD: OCZ Agility 3 (60GB) |
HDD: Seagate Barracuda (500GB) | GPU: MSI HD 7950 Fwin Frozr iii | PSU: Corsair CX600 | Case: NZXT Phantom 410 w/ NZXT Blue LED strip
https://linustechtips.com/topic/18173-problem-with-clearing-data-on-drives/
This is only a suggestion, but why not boot up into your Windows Install disc and use that to format all the drives?
Edit: While you're at it.. disconnect the main drive and connect another drive to get more done at once and without causing an accidental wipe of the original drive.
MOBO - Asus Sabertooth 990FX R2.0   CPU - AMD Phenom II X6 1055T @ 3.5GHz - Corsair H80i   RAM - 2x Corsair Vengence 4GB DDR3 @ 1666 MHz
GPU - SAPPHIRE 100362-3L Radeon R9 290 4GB Tri-X OC  Sound - ASUS Xonar DSX  PSU - Thermaltake SMART M Series SP-850M 850W
I roll with sigs off so I have no idea what you're advertising.
This is NOT the signature you are looking for.
Ok thanks! I created a DBAN disk, I think doing it through a utility like that will be a lot easier than through Windows. Also the data on the drives is not critical and will not make any sense to anyone who accesses it from what I have been told, so I will wipe them but I don't think I will have to run it multiple times or 'Zero-fill' it, but thanks for the link :)
