Hello.
I recently brought an old PC back from the dead (I don't think it's a zombie, it doesn't look like it), it boots into Windows XP just fine, but after running it for a while, it powers itself off.
Any ideas? Could the CPU be overheating?
LTT's unofficial Windows activation expert.
https://linustechtips.com/topic/180330-sudden-power-off/
Hello.
Either an overheat, or an incompatible power supply.
QUOTE ME OR I PROBABLY WON'T SEE YOUR RESPONSE
My Setup:
Desktop
CPU: Ryzen 9 3900X  CPU Cooler: Noctua NH-D15  Motherboard: Asus Prime X370-PRO  RAM: 32GB Corsair Vengeance LPX DDR4 @3200MHz  GPU: EVGA RTX 2080 FTW3 ULTRA (+50 core +400 memory)  Storage: 1050GB Crucial MX300, 1TB Crucial MX500  PSU: EVGA Supernova 750 P2  Chassis: NZXT Noctis 450 White/Blue OS: Windows 10 Professional  Displays: Asus MG279Q FreeSync OC, LG 27GL850-B
Main Laptop:
Laptop: Sager NP 8678-S  CPU: Intel Core i7 6820HK @ 2.7GHz  RAM: 32GB DDR4 @ 2133MHz  GPU: GTX 980m 8GB  Storage: 250GB Samsung 850 EVO M.2 + 1TB Samsung 850 Pro + 1TB 7200RPM HGST HDD  OS: Windows 10 Pro  Chassis: Clevo P670RG  Audio: HyperX Cloud II Gunmetal, Audio Technica ATH-M50s, JBL Creature II
Thinkpad T420:
CPU: i5 2520M  RAM: 8GB DDR3  Storage: 275GB Crucial MX30
https://linustechtips.com/topic/180330-sudden-power-off/#findComment-2421778
The PSU is a SeaSonic S12 II 430W. I'm quite sure that it's compatible, it's an old Pentium 4 system, the mobo has a 20-pin connector, the hard disk is SATA, it has 2 optical drives, both are PATA (IDE).
I will replace the thermal compound tomorrow.
https://linustechtips.com/topic/180330-sudden-power-off/#findComment-2421792
Yeah, PSU compatibility issues are rare, but I only assumed that because JayzTwoCents on YouTube had a similar issue with his recent build.
My Setup:
Desktop
Main Laptop:
Thinkpad T420:
https://linustechtips.com/topic/180330-sudden-power-off/#findComment-2421867
Use HWMonitor to check the Temps and voltages.
Check the cabling and that nothing is shortcutting the power off or cables touching the MB and messing with it. Also check in the BIOS if their is a fail safe temp to turn off, check and see if the temp has not been lowered then 75 - 90, the values vary depending on specs and company.
--- CPU:  AMD A10-7850k --- Motherboard:  ASUS X88MPlus --- RAM:  G-Skill 8GB Ripjaws X DDR3 2133 Dual --- GPU:  Integrated APU --- Case:  Aerocool Dead Silence Gaming Cube Case  ---
https://linustechtips.com/topic/180330-sudden-power-off/#findComment-2421888
