Ethernet loses connection
Go to solution Solved by LarsReviews,
The problem was solved. The Fritzbox which is used for DSL and then goes to the router has a hardware related issue. The lan jack is broken, even though it wasn't touched for the last years. This caused it to crash and that also made the 2nd router crash. My PC is the only one with a static IP so that is why mostly my PC was having that issue.
We got a new Fritzbox, the 7940 which replaces the dual router setup. Now everything is fine again.
Thank you for your help.
Edit: ups, I mean 7490
Hi,
I have a Asus Z87a Motherboard and I use the onboard NIC. From time to time the Windows Ethernet symbol shows a yellow dot and I have no connection, To fix this I either have to restart my PC or deactivate and activate the NIC in the Device Manager, I already tried a different driver and I have reinstalled it a couple of time with no luck. I don't know what to do now.
UPDATE 13.08.2014 see below
Intel 4790k | Asus Z97 Maximus VII Impact | Corsair Vengeance Pro Series 16 GB 1866Mhz | Asus Strix GTX 980 | CoolerMaster G550 |Samsung Evo 250GB | Synology DS215j (NAS) | Logitech G502 |
https://linustechtips.com/topic/179288-ethernet-loses-connection/
I would say it has to do with your modem/router/Internet service provider. Bad ISPs then to drop connection from time to time, and a reconnect usually helps (like what you do to deactivate and reactivate)
If you dont have this problem on any other devices then it could be your NIC itself. Hard to be sure though.
It is the only device I have that issue with.
Have you tried uninstalling the network driver and reinstalling a potentially updated one? Keep in mind you should have it already downloaded, or have a device that you will be able to transfer it from in the event it doesn't automatically try to reinstall or something goes wrong with it.
13" Macbook Pro i7 (I7-3520M) | 16gb RAM | 128gb Sandisk SSD
Current build------------------------------Future build↓
Intel Core i7-4790K 3.5GHz Quad-Core | G.Skill Ripjaws X Series 8GB (2 x 4GB) DDR3 | Asus GTX 970 Strix | Corsair 450D ATX Mid Tower | EVGA SuperNOVA 750 | MSI Z97-GAMING 5 ATX LGA1150 | 128gb Sandisk SSD | Corsair H90 94.0 CFM Liquid
Go to the manufacture website and install their given driver for ethernet.
http://www.asus.com/Motherboards/Z87A/HelpDesk_Download/    Click on Driver and Tools then your OS and find LAN and download the latest one.
--- CPU:  AMD A10-7850k --- Motherboard:  ASUS X88MPlus --- RAM:  G-Skill 8GB Ripjaws X DDR3 2133 Dual --- GPU:  Integrated APU --- Case:  Aerocool Dead Silence Gaming Cube Case  ---
I have tried the Asus Drivers and the one from chipset Manufacturer with no luck.
try flushing tcp connections its really simple and could fix the problem.
So windows button then type CMD then left click it and run as admin
then type ipconfig /flushdns ( let it do its thing )
then type ipconfig /release
then type ipconfig /renew
see if that helps any
Please Quote so i know you have replied. | If we have provided a solution to your problem mark it with answer found.
And also please read the COC and avoid the embarrassment and lecture that will ensue.
  • 2 weeks later...
Sorry about the late reply. The issue got better since doing that. But it seems, as if this also has something to do with my switch. I have 1 LAN cable going to my room, which goes into the switch. From there is goes into a AP and my PC. My sister uses my Wifi and has also experienced some problems, but to always when I have them.
  • 3 weeks later...
That does not flush connections.
/flushdns clears out you're local DNS cache
/release releases the DHCP lease on the IP the system currently ahs
/renew sends a new DHCP request from the system to the DHCP server to request a new IP address.
"Any sufficiently advanced technology is indistinguishable from magic" - Arthur C. Clarke
Just because it may seem like magic, I'm not a wizard, just a nerd. I am fallible.
Use the quote button or @<username> to reply to people | Mark solved troubleshooting topics as such, selecting the correct answer, and follow them to get replies!
Community Standards | Guides & Tutorials Troubleshooting Section
go HAM on them Network Adapters!
ipconfig /release
ipconfig /flushdns
ipconfig /renew
nbtstat -R
nbtstat -RR
netsh int reset all
netsh int ip reset
netsh winsock reset
lol no don't, unless you want to. I just had a text document saved "NIC Nuke" with all these commands in case I forget.
System Specs
CPU: FX-6350 (O.C. 4.6GHz Stable / 4.8GHz Unstable-incomplete)Cooler: Hyper Evo 212Mobo: 990fxa-ud3 Rev.3RAM: G.Skill 1866 2x4GBGPU: MSI R7870-2GD5T/OC x2 (O.C. 1120/1320-Summer 1160/1350-Winter)NIC: PCE-N15PSU: Seasonic X-650 Gold+Case: CM Storm ScoutStorage: 120 Samsung 840 SSD 2x1TB HDDBattery Backup-APC 650Mouse: G600Keyboard: G510Gamepad: PS3 Dualshock 3 VIA BluetoothMonitor: ViewSonic VX2253 (cheap from craigslist, owned this before build)
ipconfig /release
ipconfig /flushdns
ipconfig /renew
nbtstat -R
nbtstat -RR
netsh int reset all
netsh int ip reset
netsh winsock reset
You're missing a super important step... restarting the PC. If you run netsh int ip reset, you NEED to restart. Essentially what it does is uninstall the TCP/IP stack, and schedule it's reinstallation for next boot. Other than that, yeah, that will effectively nuke the shit out of your NIC settings. I should point out thought, the NBTSTAT -R, and -RR aren't entirely needed anymore, unless you're on an old system, using a WINS server.
glad to see you have it resolved can you mark the post at answerd so people dont go on ranting on how to fix it and get very off base. thanks!
I hate doing that. I appreciate everyones answer, so I usually don't want to pick one. :D
Yep, restart is an important step. Just not in my notes as I should know that, but will add that to the notes for sharing purposes lol.
System Specs
Just script it in to the end of the NIC nuke, and you won't have to worry about doing it manually :P
