Hi,
I am looking to get a new graphic card as mind is old and failing but i kind of need some help.
I have settled on the GTX 780 but what i really want to do is to have a custom water cooling loop and i am not sure what card to buy
Just hoping someone here can help with some information if there know a place i can find compatible cards for a block or if you already have a card and water block that you are using
all information will be useful and greatly appreciated
thanks in advance.
https://linustechtips.com/topic/177117-780-water-cooling/
Hi,
thanks in advance.
You want to get a reference card because they can fit most waterblocks.
One that looks like this the brand doesn't matter that much.
https://linustechtips.com/topic/177117-780-water-cooling/#findComment-2376141
