Hi everyone, this is my first post (yay :D )
I'm just wondering if I should:
A ) Just upgrade my graphics card and power supply
or
B ) Build a whole new rig when Haswell comes out
My current build is:
Core 2 Quad Q6600
Ati 4870
4 Gb Ram
400w PSU
Thanks
https://linustechtips.com/topic/17517-need-advice-for-upgrade/
Completely new one. You would be bottle-necked real bad if you just replace 1 or 2 parts.
Desktop:  MSi GTX 680 Lightning - MSi Mpower Z77- i7 3770k - Asus Xonar DGX  - 16Gb Ares Ram - GX 750w PSU
Laptop: MSi GE 60 - GTX 765m - i74700MQ - 8gb ram
https://linustechtips.com/topic/17517-need-advice-for-upgrade/#findComment-201945
I say build a whole new computer when Haswell comes out.
No matter what gpu you buy right now, you're going to be bottlenecked by your cpu.
So yeah, what Alpha said.
CASE: Haf 912+ CPU: i5 3570k - 4.2ghz COOLER: Hyper 212 evo MOBO: Gigabyte GA-z77x-UD5H GPU: MSI GTX 560 TI Hawk RAM: Corsair xms3 4x2gb SSD: Crucial m4 64gb HDD: 2x1tb+250gb hdd SOUND: Asus Xonar dg HEADSET: Steelseries Siberia v2
Raspberry Pi XBMC
https://linustechtips.com/topic/17517-need-advice-for-upgrade/#findComment-201952
Build w hole new rig when haswell comes out. It will be worth your money and it will last for a long period of time.
CPU: AMD FX-6100 Black Edition @3.9GHz GPU: XFX 7970 DD (1062/1520 MHz) MOBO: ASUS Sabertooth 990FXA(1st Revision) RAM: Corsair Vengeance 16GB @ 1333MHz Storage: Corsair Force 3 120GB(Boot) + WD Green 1TB(storage) PSU: FSP AURUM 600W(80+ Gold) CPU Cooler: Cryorig M9a  Case: NZXT Tempst 410 Elite(Mid-Tower) Mouse: Logitech G602(Manufacturer Refurbished) Keyboard: Noppoo Choc Mini(Cherry MX Blue) AUDIO:Sennheiser HD 598+ASUS Xonar DGX Monitor: LG M2280DF 21.5" 1080p(TN-75Hz)
https://linustechtips.com/topic/17517-need-advice-for-upgrade/#findComment-201954
You're on a computer enthusiast forum, of course everyone will say build a whole new rig ;)
In all honestly the Q6600 is still half decent in games.  If you wanted a moderate upgrade say to like a GTX 660 or something I'd stick with what you've got and just change the GPU, add another 4GB of RAM.  Bottlenecking wouldn't be bad really.  If you want to play everything on max settings and all that, then I'd recommend a new rig though.
https://linustechtips.com/topic/17517-need-advice-for-upgrade/#findComment-202187
