Oh my gosh I was goanna get the freaking 350d case for a build but a bunch of people were all like oh no don't get a 100$ case get a buttugly 15$ case off amazon and get a 500th ssd instead lol (exaggeration) but still really??? What micro atx case with side glass panel????? Tell me your better idea or is a 350d fine???
Its all looks these days
https://linustechtips.com/topic/173666-micro-atx-case/
@luke_2bossly what other components are you getting? If you're on a very tight budget and getting low end components then you're probably better off getting a cheaper case and some better gear, however if you're already getting decent gear and want something that looks good and is solid then a 350D will do just fine for you.
EDIT: Tagged wrong 'Luke', apparently the tagging system doesn't like underscores (so it took 'Luke_2bossly' as 'Luke')
https://linustechtips.com/topic/173666-micro-atx-case/#findComment-2306657
It tags me regardless, Don't worry i'm used to it.
Intel i7 3770K [] Asrock Z77 Extreme 4 [] MSI R9 290X 4GB [] 16GB  G.SKILL 2133Mhz [] Crucial MX100 256GB [] WD Black 1TB [] XFX Pro 850W [] Fractal Define R3 [] Func MS-3 R2 [] Corsair K60 []
https://linustechtips.com/topic/173666-micro-atx-case/#findComment-2306957
Reading your post hurt.
Some people want to show off their components. They like the features of the cases, and the build quality and style of it, and the ease of assembling your components inside. I'm one of these people. I would rather buy an expensive case with good air and watercooling compatibility and everything else I want, rather than a bigger SSD or more expensive motherboard.
https://linustechtips.com/topic/173666-micro-atx-case/#findComment-2307118
