Right so I wont be buying this build until the distant future I am a content creator (youtuber)
So I will be needing 2 1440p 27" monitors one for my channel up and other for internet gaming p**n etc.
atleast be needing 16gb ram for rendering and some other applacations that involve ram this will be ddr4 ram as this build will be far future build
i7 skylake processor highest end cpu not a x chip just the best unlocked series
Mobo top end x whatever at the time great for oc and feutures and looks nice
cooler be either best h series cooler or swiftech
gpu right id like a gtx 90 series the dual chip card non refernce card 1 they are great peformers and have lots of v ram which Will benefit my dual monitor
Keyboard id like the top end k series keyboard I just love em!!!
Mouse you guessed it best corsair m series there brilliant and feel lush
mic me being a content creatator id be needing a high quality mic like a at2020 or a blue yeti
Os something snappy and has features
case full tower full window along the lines of a 760t
EVREY FAN WILL BE A NOCTUA!!!!!!!!
just want to know the price in ££££££££ how much to save and how much will get the job done thnnnnnxx
https://linustechtips.com/topic/172974-need-advice/
you will probably need more than 16 gigs, rarther just get 32
you will also needs lots of storage
we can make a quick build in pcpartpicker to see what price comes up
instead of going balls to the walls with cooling and mobo, we can try fit in the sixcore and get a ~40 - 50 pound tower cpu cooler with 2 fans. much more reliable and cost effective.
https://linustechtips.com/topic/172974-need-advice/#findComment-2298465
naa not worried about price to performance
https://linustechtips.com/topic/172974-need-advice/#findComment-2298518
Yea, no problem. Sixcore isnt really price performance either :P just an option
but you get quad channel, 12 threads ready to crunch workload
for reliability however, a noctua /bequiet tower cooler for examplewould be preffered over AIO. its your choice though.
https://linustechtips.com/topic/172974-need-advice/#findComment-2298550
best of evreything really no budget intended just need a rough amount to start saving
https://linustechtips.com/topic/172974-need-advice/#findComment-2298563
CPU: Intel Core i7-4790K 4.0GHz Quad-Core Processor  (£256.99 @ Ebuyer)
CPU Cooler: Swiftech H220 55.0 CFM Liquid CPU Cooler  (£108.11 @ Amazon UK)
Motherboard: Asus MAXIMUS VII HERO ATX LGA1150 Motherboard  (£160.76 @ Scan.co.uk)
Memory: Kingston Beast 16GB (2 x 8GB) DDR3-2400 Memory  (£120.99 @ Amazon UK)
Storage: Samsung 840 EVO 500GB 2.5" Solid State Drive  (£179.99 @ Aria PC)
Storage: Western Digital Caviar Black 1TB 3.5" 7200RPM Internal Hard Drive  (£61.51 @ Amazon UK)
Video Card: Asus GeForce GTX Titan Black 6GB Video Card  (£767.22 @ CCL Computers)
Case: Corsair 750D ATX Full Tower Case  (£121.76 @ CCL Computers)
Power Supply: SeaSonic Platinum 860W 80+ Platinum Certified Fully-Modular ATX Power Supply  (£176.54 @ Amazon UK)
Optical Drive: Lite-On iHAS124-04 DVD/CD Writer  (£11.74 @ CCL Computers)
Operating System: Microsoft Windows 8.1 (OEM) (64-bit)  (£79.89 @ Amazon UK)
Monitor: Asus PB278Q 27.0" Monitor  (£424.44 @ Amazon UK)
Case Fan: NoiseBlocker NB-eLoop B12-PS 58.1 CFM 120mm  Fan  (£18.26 @ Overclockers.co.uk)
Keyboard: Corsair Vengeance K70 Wired Gaming Keyboard  (£210.00 @ Amazon UK)
Mouse: Corsair Vengeance M65 Wired Laser Mouse  (£51.52 @ Amazon UK)
Other: BLUE Yeti (£90.00)
Total: £3519.70
this would be ideal, so consider this price being upper limit
https://linustechtips.com/topic/172974-need-advice/#findComment-2298629
