So today I took my 4770k out of my socket and then noticed that around 2 or 3 pins were bent. I don't think my removal had an impact on the pins. Will my new 4790k still run with these slightly bent pins?
Posted Image
Hope you can spot them.
And another question, will amazon still accept a 4770K that's missing only the quick start guide? I have the sticker too, but I lost the quick start guide!
Are you new? Please read CoC  Before posting! PLEASE SELECT 'AUTOMATIC' FOR FONT COLOR FOR US DARK THEME USERS (Only for dark shades)If you can read this, it means you need to change to NIGHT THEME (bottom left above LMG logo) Please follow your threads and Quote people when replying to them. Mark your problem as solved if answered. Don't spam, nobody likes a spammer. DO NOT QUOTE IMAGES! BE NICE!
https://linustechtips.com/topic/172816-bent-pin/
Posted Image
https://linustechtips.com/topic/172816-bent-pin/#findComment-2296360
Sorry you didn't get an answer earlier;
This is what I used when a buddy had the same scenario. It also comes with an NCIX video with Linus.
Be extremely careful.
I really wish that we'd just make organic hardware already, that grows and adapts to the demands it needs to meet. That way, grannies' computers can be floppy sacks of organicness and the 12 year old Minecrafters will look like the guys that only do bicep curls, and the nerdy programmers will finally have justice, with their body-builder rigs that skipped leg day.
CPU: i7-4770k 4.8GHz | Motherboard: Asus Maximus Hero | RAM: 16gigs 2133MHz | GPU: SLI Gigabyte OC 2gb 770's | Case: INWIN GRone | Storage: 1tb Blue, 60gb SSD | PSU: Silencer MK II 950w | Cooling: Modded H100i
https://linustechtips.com/topic/172816-bent-pin/#findComment-2296434
It's the socket that has the bent pins, though, not the CPU itself. The credit thing may still work though.
https://linustechtips.com/topic/172816-bent-pin/#findComment-2296445
I don't think this would work because the pins in LGA1150 are bent at an angle on purpose anyway so this technique is quite difficult.
https://linustechtips.com/topic/172816-bent-pin/#findComment-2296454
Will the mechanical pencil technique work?
https://linustechtips.com/topic/172816-bent-pin/#findComment-2296476
It may do. Whichever method you use though, just be incredibly careful to not bend them too far, you'll just end up with the same problem but with the pins in a different direction, or worse, snap them off completely.
https://linustechtips.com/topic/172816-bent-pin/#findComment-2296489
Well it payed off!! The motherboard now works with my brand new 4790K!
https://linustechtips.com/topic/172816-bent-pin/#findComment-2301332
Awesome! Now it's time to OC that bad boy.
Im at 4.8Ghz already! Had to take the voltage up, but WOW this CPU is awesome!
https://linustechtips.com/topic/172816-bent-pin/#findComment-2304506
