So I just got done building a rig. When I launch Arma 3 in full screen my display says not supported. When I launch other games like
Borderlands 2 it works just fine.
I am using a Sony Bravia TV with a VGA cable plugged in to a VGA to DVI in my EVGA GTX 780 GPU.
Thanks for the help!
https://linustechtips.com/topic/172669-cant-display-games-help/
VGA ... :o
Eh all I know is sometimes I have had to shut off my display or reboot my pc and then suddenly I get a picture.  I don't have an explanation for why this works but it has worked before.
Hmmm as for your exact problem with Arma 3 well does your display support the default resolution your game is set at?
Too many ****ing games!  Back log 4 life! :S
https://linustechtips.com/topic/172669-cant-display-games-help/#findComment-2294886
Should've read what the box said on the GTX 780. VGA to DVI is not supported. Got the same card and it is printed on the box with bigger letters than the others. Go HDMI or, DVI completely.
CPU:Intel I7-6700k , CPU Cooling: Cooler Master Hyper 212 EVO MB: Asus Maximus VIII Hero, Ram: Kingston 2666 Mhz 16GB, GPU: EVGA GTX 1080 SC ACX 3.0, PSU: Corsair AXi 860W, HDD: Seagate Barracuda 1x2TB, WD Green 1TB, Seagate Barracuda 1TB, Samsung 1TB, SSD Samsung 840 120GB (OS DRIVE), SSD Samsung 840 250GB, Case: Enermax Fulmo GT.
https://linustechtips.com/topic/172669-cant-display-games-help/#findComment-2296025
