Remove front panel Coolermaster k280
Go to solution Solved by CookieTheMonsta,
Front panels are usually removed by just pulling them from the bottom towards yourself. Or maybe you have some kind of screws in the case which you unscrew and then pull off front panel.
Hello community, i've been wanting to replace my coolermaster k280's front fan with some other one (or 2) but i've come up against a wall when i tried to get to where's that tricky little fan. so, if someone could just send me a pic, or tell me how to remove this panel, would be great.
Thanks in advance.
https://linustechtips.com/topic/167541-remove-front-panel-coolermaster-k280/
[spoiler= My "gaming rig" ]
  • CPU: Intel i5 2500
  • Motherboard: Asrock B75M-GL R2.0
  • RAM: 1x4 GB 1333 Mhz Kingston, 1x4 GB 1333 Mhz Transcend
  • GPU: MSI GTX 770 Gaming OC 2 GB
  • Case: Zalman Z3 plus white
  • Storage: WD Blue 500 GB, WD Black 1 TB
  • PSU: LC POWER 650W ATX v2.3 80+ bronze
  • Display(s): Acer V223HQ
  • Cooling: Scythe SCKTN-3000
  • Keyboard: CoolerMaster QuickFire TK MX blue
  • Mouse: Sharkoon Fireglider Laser Mouse
  • 2 months later...
