Hey everyone,
I'm building a rig a friends friend and he has a max budget of ~ $700. He says he will be running game engines (he's going to school for game design), and he suggested 6 - 8gb ram, a good video card, a fast cpu. I've already decided to go AMD as that will save money on the cpu as well as the mobo. However, I'd like some advice on a decent video card that would fit in this budget along with a PSU (modular would be way better, I'm guessing 700w would be more than enough).
Thanks!
Me: Yeah I just really can't get my H220 working again, I've tried everything that was suggested in the forum.
Brian (Swiftech Support): Hmm, have you tried slapping it?
https://linustechtips.com/topic/16720-help-me-pick-parts/
They're sharing a drink they call loneliness, but it's better than drinkin' alone...
BitFenix Prodigy Black / Intel Core i7 3770K / Gigabyte GA-Z77N-WIFI mITX / ASUS GeForce GTX 660Ti DCUII 2GB / Corsair Vengance LP 8GB (2x4096MB) CL9 1600Mhz / Corsair SF600 - 600W  / Corsair H70 Push Pull
https://linustechtips.com/topic/16720-help-me-pick-parts/#findComment-191155
Ah, well not much I can do about it now
https://linustechtips.com/topic/16720-help-me-pick-parts/#findComment-191162
http://pcpartpicker.com/p/XuXa
Something around this?
Check up on the PSU, but Seasonic usually makes very good PSUs.
Tahiti XT 7870 is actually something around a 7930.
Case he will have to decide himself =P
And using stock cooler for now, can add laters.
Frost upon these cigarettes.... lipstick on the window pane...
https://linustechtips.com/topic/16720-help-me-pick-parts/#findComment-191208
