http://www.amazon.de/klein-gro%C3%9Fe-Kamera-Schutzh%C3%BClle-beidseitig-Au%C3%9Fenseite-SLR-Digitalkameras/dp/B00IOURSF8/ref=sr_1_28?ie=UTF8&qid=1402739670&sr=8-28&keywords=dslr+neopren
I like this product a lot.
But i think it wouldnt be compatible with my D5100 an with my battery grip.
Can you help me find a larger version of this or a similar product?
cheers.
https://linustechtips.com/topic/166366-need-help-finding-a-larger-camera-bag/
I can't 100% help you with that,I'm no photo expert but I couldn't stop myself from umm...Just...ehh..See for yourself.
Ehm...
Sorry for off-topic.
Anyway,I found this for your camera : http://www.amazon.de/mittel-gro%C3%9Fe-Kamera-Schutzh%C3%BClle-beidseitig-Au%C3%9Fenseite-SLR-Digitalkameras/dp/B00IOUB084/ref=pd_sim_sbs_ph_7?ie=UTF8&refRID=0XC7FYQWM3AHQZJ4Q7XY
Don't know if it will also work with the battery grip though.
-snip-
Ehm...
oh god. the internetz  :D
thanks, but i guess its prety much the same product.. too bad.
Edited by Rheinwasser
