Hello everyone, I recently swapped case for the first time, but I don't have something clear.
Case is Fractal Design Refine R4, Motherboard is MSI  P67A-GD53, Cpu is Intel i5-2500.
I have 2 HDD and a SSD installed on the bottom,
and the middle hdd tray removed from the case.
My goals were silence and cooling.
1)While building, I couldn't install the motherboard backplate,because it couldn't fit...I decided to remove it completely.
Do I need it?
2) How should I make use of the fan control switch in the front of the case?
The one where you set the voltage to 5V,  7V or 12V..
I have the rear fan and the bottom front case fan installed.
2.1) should I have 2 front fans?
3) At which target speed should I set the Cpu fan ?
In the BIOS is currently set it to go to max speed when CPU temp reaches 65 C..
https://linustechtips.com/topic/165629-some-tips-after-swapping-case/
  • 2 weeks later...
