R9 280x Crossfire problem - Need Help
Hi folks.
I've got a problem here that is driving me crazy and after a week+ of researching and reading still can't get to the solution.
I have a Xfx R9 280x and recently I bought another one to do a Crossfire.
Thing is that I am not getting better performance than before with only one card. When checking the GPU usage on games like BF 3 or BF4, I get 40-60% on both GPU's of usage. FPS is alomst the same than before, when running a single card.
I play at 1080p (on a 1440p monitor for now, vsync off) and I get around 80-110 max FPS with Crossfire enabled, on medium settings. And with a single card, I am around 75-100 FPS.
With the two XFX R9 280x, shouldn't I be able to get at least 100 FPS stable in 1080p, medium settings? And why on earth is my gpu usage only on 40-50% on crossfire and 80-90% on a single GPU? Is the fact that my monitor is only 60hz refresh rate holding back the GPU's even if i have Vsync off?
My specs
Core I5 2500k at 3.7 GHZ
Gigabyte H67 h67m-ud2h-b3 motherboard
12 GB RAM
120 GB SSD
Tried already
Updating drivers
Disabling ULPS
Disabling Frame Pacing
Using Mantle (runs a bit better, but nothing specatcular)
Fresh OS install.
Please help me out here!
Thanks!!!
ah ha i found your problem
you mobo PCI-E
http://www.gigabyte.sg/products/product-page.aspx?pid=3769#sp
- 1 x PCI Express x16 slot, running at x16 (PCIEX16)
* For optimum performance, if only one PCI Express graphics card is to be installed, be sure to install it in the PCIEX16 slot.
- 1 x PCI Express x16 slot, running at x4 (PCIEX4)
- 2 x PCI Express x1 slots
(All PCI Express slots conform to PCI Express 2.0 standard.)
the second PCI-E slot is running at 4X speeds and since it is Gen 2 PCI-E
that even slower!!!
so your second 280X is getting choked
