Hey everyone I am new to this forum as you guys can tell by my post count. I am currently in Grade 11 and we all have to complete a Research Project based on a chosen topic. As I love anything to do with computers and currently planning a build (rough specs- http://pcpartpicker.com/p/jwgNvK {will probably wait for the new CPU from Intel}) I wish to base my Project off that. One random topic off my head is "How does graphic cards directly impact the graphical performance of a computer" I am open to any suggestions and ideas from the awesome people of this forum, cheers.
CPU: i9-13900K |  MOBO: Asus ROG Strix Z790-E | Cooling: Corsair iCUE H150i Elite 360mm AIO | RAM: Corsair Dominator RGB 32GB 6200MHz CL36 DDR5 | GPU: Gigabyte RTX 4080 Gaming OC 16GB | Case: Corsair 5000D Airflow| PSU: Seasonic Prime GX-1300 Gold 1300W | Keyboard: Corsair K95 Platinum | Mouse: Logitech G Pro X Superlight 2 DEX w/ Powerplay
https://linustechtips.com/topic/164393-research-project-ideas/
budget?
also please post in the right sub form next time this belongs in new builds and planing
use the quote button if you want my help
Specs
https://linustechtips.com/topic/164393-research-project-ideas/#findComment-2187049
budget?
this isnt a build plan... the guy wants to do research on how GPU's affect performance in gaming applications
https://linustechtips.com/topic/164393-research-project-ideas/#findComment-2187072
halp! :D
The graphics card directly impacts the graphical performance of a computer, by being the graphical unit and processing graphics.
Hence the name GPU - Graphics Processing Unit, it's that simple really.
https://linustechtips.com/topic/164393-research-project-ideas/#findComment-2187073
yea but i want to know how much of a budget hes "looking" at so we can change around the gpu
Specs
https://linustechtips.com/topic/164393-research-project-ideas/#findComment-2187083
This gives me an idea. Should try and test how much does power delivery really differ between a cheap and an expensive motherboard. That could make an interesting topic. How much power can VRM effectively handle, how much noise it produces, handling of spikes, etc.
CPU:Intel Xeon X5660 @ 4.2 GHz RAM:6x2 GB 1600MHz DDR3 MB:Asus P6T Deluxe GPU:Asus GTX 660 TI OC Cooler:Akasa Nero 3
SSD:OCZ Vertex 3 120 GB HDD:2x640 GB WD Black Fans:2xCorsair AF 120 PSU:Seasonic 450 W 80+ Case:Thermaltake Xaser VI MX OS:Windows 10
Speakers:Altec Lansing MX5021 Keyboard:Razer Blackwidow 2013 Mouse:Logitech MX Master Monitor:Dell U2412M Headphones: Logitech G430
Big thanks to Damikiller37 for making me an awesome Intel 4004 out of trixels!
https://linustechtips.com/topic/164393-research-project-ideas/#findComment-2187095
Well this is mainly ideas for my research project. The partlist is just something i added in, has nothing to do with the rest. I have around two months plus to work on this so i cant print out an A4 page saying GPU stands for graphics processing unit... It processes graphics. -.- id have to go into alot of detail like explaining Nvidia's Cuda core and AMD's Stream processors and maybe then do a comparison. Open for suggestion to other ideas.
https://linustechtips.com/topic/164393-research-project-ideas/#findComment-2187164
https://linustechtips.com/topic/164393-research-project-ideas/#findComment-2187172
How does a 11 year old get a 2000 dollar pc?
Current rig: CPU: AMD FX-8120  Cooling: Corsair H100i  Mobo: ASRock 970 Extreme 3  RAM: 8GB 1333Mhz  GPU: MSI GTX 660Ti Power Edition  Case: Fractal Design Define R4  Storage: 2TB Seagate HDD + 128GB Crucial SSD  PSU: be quiet! 730W bronze
https://linustechtips.com/topic/164393-research-project-ideas/#findComment-2187194
sorry changed to grade 11, im 16. pitching in all my money and parents paying the rest, since dads gonna use it aswell for his work which also requires high computing power.
https://linustechtips.com/topic/164393-research-project-ideas/#findComment-2187204
thanks ill add that to my list.
https://linustechtips.com/topic/164393-research-project-ideas/#findComment-2187209
Well, graphics cards are the component responsible for the main rendering and calculating of 3D images, such as video games, CAD, or some other form of graphics media.
Some specialized graphics cards are meant for professionals, and aren't great with gaming, despite their higher price tags. Nvidia's Quattros, and AMD's FirePros are examples.
Finally, GPUs can also be used to accelerate online programs such as Unity or Flash, and can also be used for math calculations, simulating physical systems, and so on.
Basically, the GPU is in charge of what you. See on screen. The faster the GPU, the more quickly it can prepare and 'send off' frames to the monitor.
https://linustechtips.com/topic/164393-research-project-ideas/#findComment-2187235
cheers
https://linustechtips.com/topic/164393-research-project-ideas/#findComment-2187292
All of it.
Okay, I will try to be helpful since
since graphical performance based on graphics cards can be summed up by "all of it", here are some ideas I have for alternative topics.
• You could do one on how each component has its role to play in the overall power/speed of a computer, and not just the clockspeed or the RAM speed or how much RAM you have or what GPU you have.
• You could do a thing on bottlenecking and how that system is very much not bottlenecked.
• Water cooling and how it works
•Overclocking
Hope this helps!
https://linustechtips.com/topic/164393-research-project-ideas/#findComment-2187325
All of it.
•Overclocking
Hope this helps!
thanks alot, i will add them to the list.
https://linustechtips.com/topic/164393-research-project-ideas/#findComment-2187359
thanks
https://linustechtips.com/topic/164393-research-project-ideas/#findComment-2187391
