what kind of simple fan controller with nobs that controls the fans using PWM are out there? I don't want anything flashy just a simple black controller.
My System Specs: (Short list) i7 4770k, GTX 780, many SSD's, a 2 TB HDD(deceased :( ), Corsair 650D. Full list: http://pcpartpicker.com/user/kchriz6097/saved/8dh7YJ
Upgrade Plan: Acquire some Black Noctuas then add 16 or 32GB of 2133MHz memory
https://linustechtips.com/topic/164286-pwm-fan-controller/
PWM sized connectors doesn't mean PWM control. The Sentry Mix uses voltage control.
The only PWM controller with multiple channels available is the Aquaero 6, but it is really a massive overkill for air cooling only. Your motherboard will have a PWM port on the CPU fan header (and a mirror on the CPU OPT header). So you can connect devices using a PWM splitter to those headers if you want the same control over all of them. There are also many controllers with a single PWM header in the $50+ range.
https://linustechtips.com/topic/164286-pwm-fan-controller/#findComment-2187957
