Aorus 5090 issues
Solved by Hinjima,
That is certainly a bit of flex but I have seen way worse on GPU's and motherboards that are working perfectly fine.
Even my RTX 4080 has a bit of PCB bend after using the built in GPU holder on my Fractal Torrent.
I'd say it was looking similar to this before I lowered the GPU holder a tad.
I am not saying that this is not whats causing the issues, it just doesn't look 'bad enough' to be causing it.
