Posted December 19, 2025 hello! I apologize if I am not posting in the correct section. I have a question, I would like to purchase a power source for my configuration, at the moment I have a focus gx 850w and I keep thinking that a ryzen7 9800x3d, motherboard msi x870e carbon wifi and rtx 5080 suprim soc is not enough for my configuration, what advice do you have to change it or keep it, and if I change it, what do you recommend Link to comment https://linustechtips.com/topic/1628885-power-supply/ Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted December 19, 2025 7 minutes ago, Celes13 said: hello! I apologize if I am not posting in the correct section. I have a question, I would like to purchase a power source for my configuration, at the moment I have a focus gx 850w and I keep thinking that a ryzen7 9800x3d, motherboard msi x870e carbon wifi and rtx 5080 suprim soc is not enough for my configuration, what advice do you have to change it or keep it, and if I change it, what do you recommend Hello. A 850w is plenty fine for a 9800X3D and a RTX 5080, even when overclocked. The Focus GX is also a good PSU, keep it, nothing to worry about. You could actually run that system of a solid 650w. Link to comment https://linustechtips.com/topic/1628885-power-supply/#findComment-16842402 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted December 19, 2025 Author 3 minutes ago, Hinjima said: Hello. A 850w is plenty fine for a 9800X3D and a RTX 5080, even when overclocked. The Focus GX is also a good PSU, keep it, nothing to worry about. You could actually run that system of a solid 650w. thanks for the answer, I'm waiting for other opinions Link to comment https://linustechtips.com/topic/1628885-power-supply/#findComment-16842404 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted December 19, 2025 6 minutes ago, Celes13 said: thanks for the answer, I'm waiting for other opinions Sure. I ran my overclocked 9800X3D and overclocked RTX 4080 ( same power draw as a stock 5080 ) with a 750w for a long time. 9800X3D will draw a max of 120w at 100%, RTX 5080 will sit at 340-370w at 100% usage, leave another 80-110w for the rest of your system including SSD, Fans etc. Thats 610w if you are using everything at 100%, you rarely if ever do that during gaming. 850w PSU is pleenty Link to comment https://linustechtips.com/topic/1628885-power-supply/#findComment-16842406 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted December 19, 2025 Author 15 minutes ago, Hinjima said: Sure. I ran my overclocked 9800X3D and overclocked RTX 4080 ( same power draw as a stock 5080 ) with a 750w for a long time. 9800X3D will draw a max of 120w at 100%, RTX 5080 will sit at 340-370w at 100% usage, leave another 80-110w for the rest of your system including SSD, Fans etc. Thats 610w if you are using everything at 100%, you rarely if ever do that during gaming. 850w PSU is pleenty thank you very much for the answers, I was worried because I recently changed the rtx 4080 super to the 5080 and I was afraid that something might burn Link to comment https://linustechtips.com/topic/1628885-power-supply/#findComment-16842411 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted December 19, 2025 1 minute ago, Celes13 said: thank you very much for the answers, I was worried because I recently changed the rtx 4080 super to the 5080 and I was afraid that something might burn No Problem at all. Nah, you'll be plenty fine The Focus GX is a good PSU with quality cables, the 5080 barely draws any more power than an RTX 4080 Super. You have absolutely nothing to worry about. Time to play some video games! Link to comment https://linustechtips.com/topic/1628885-power-supply/#findComment-16842413 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted December 19, 2025 Author 15 minutes ago, Hinjima said: No Problem at all. Nah, you'll be plenty fine The Focus GX is a good PSU with quality cables, the 5080 barely draws any more power than an RTX 4080 Super. You have absolutely nothing to worry about. Time to play some video games! Link to comment https://linustechtips.com/topic/1628885-power-supply/#findComment-16842415 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
