I am planning on building a gaming PC soon (my first!) and would like some feedback on the parts before I go ahead and order.
http://pcpartpicker.com/user/NoctHorn/saved/dD7v6h
If you suggest any changes, try to avoid changing the price.
Here are a few questions I have: How big of a difference does an SSD make?  Is there a better one for a similar price?
I feel a little uncomfortable about the motherboard based on reviews from newegg.  What do you think about it?
Is the graphics card I have selected a good quality one?  Is there a better one for the same price?
Any other observations about the system would be appreciated.  Note that I have already purchased the case.
i5 4670k (can OC to 4.4Ghz) - Hyper 212 evo w/ AC MX2 - XFX Radeon R9 280X8GB ADATA XPG V2 DDR3-1600 - MSI Z87 G41 - Corsair CX600M 600W PSU - 1TB HDD - 120GB SSD
https://linustechtips.com/topic/162579-final-checks-for-a-pc-build/
This looks really good. The PSU is meh but with 20% off it's the best bang for your buck.
@NoctHorn
Why 4670K with a B85 motherboard? A non-OC 4670 is cheaper, even a 4440 would do IMO.
You would also need an aftermarket CPU cooler in order to OC your 4670K correctly.
The rest looks fine, I don't know much about that SSD though.
I never trust users reviews (unless they are very explicit), people will usually only do a review/rating if they've been really disappointed and are mad (usually because of a faulty product and not a general problem with the hardware), or for some reason they are very happy and will write a biaised review.
Instead, trust complete reviews that really go in depth.
Actually, the 4670K is cheaper right now at Microcenter.  I might overclock in the future but not right now.  Is there a better motherboard for future overclocking that is similarly priced?
