Hi guys,
I have a relatively large restaurant (100 covers) and am having terrible wifi issues affecting both guests and staff.
As I work from site, whether it’s my laptop (Asus Zenbook 14 OLED) or my Pixel 8, Wi-Fi speed is terrible.
Connecting to the AP(s) isn’t an issue but once connected, wi-fi link speed frequently fluctuates between 800Mbits at the high end then a moment later its down at <20Mbit.  Few mins later its at 300 then down to 5….
My pipe to the outside world isn’t an issue as I have BTNet which is a high resilience leased fibre line (1000/100) and as I can be the first one in the door in the morning, interference / conflicts with other wi-fi clients seems unlikely.
The vast majority of network devices on the lan are hard wired except for 3 Ubiquity APs. 1 private AP serves the basement and shares the same SSID with another private AP on the restaurant floor. A 3rd AP is for guest use only, also on the restaurant floor.
Connecting to either the guest or private AP results in the same behaviour.
My partners iPhone and Surface Pro have the same issues.
The only ‘fixed’ Wifi clients on the network are the 3 Ubiquity APs, a handful of tablets for kitchen / delivery controls, an iPAD at the front desk for reservations and a couple of Rational Ovens. There is a 4th AP on the network fitted by my EPos proivider that ONLY serves the credit card machines.
The only other source of potential interference could be a Casambi Smart Lighting system that has 50 devices but they are all all Bluetooth.
Advance IP scanner doesn’t show and IP conflics.
All wired devices report expected download / upload speeds.
Short of spending a night here and unplugging all the patch cables to see if there’s an offending device somewhere on the network, does anyone have any bright ideas?
I have another restaurant on the other side of the city with pretty much the same network layout and Ubiquity APs however no Casambi lighting and that unit appears to have no wifi issues.
Cheers
Living Room PC - Lian-Li O11 XL Evo - MSI X870 Tomahawk Mobo - AMD 9800X3D - 32GB DDR5 Ram - RTX 4090 - 2TB Samsung 990Pro NVMe - Antec 1200w PSU - Dual Custom Loop Cooling - GPU cooled with EK Quantum Surface S240 + EK Quantum Surface P360M X-Flow Rads - CPU cooled with EK Quantum Surface X360M Rad
Bedroom PC - Hyte Y60 - Intel Core i5 13600k - MSI Pro-A Wifi Z790 Mobo DDR5 - 32GB Ram - RTX 5070ti - 1TB Samsung 990Pro NVMe - Corsair HX1200i PSU - CPU + GPU cooled with Hyte Y60 Corner Distro Plate - EK Coolstream S120 + EK Quantum Surface S360 + EK Quantum Surface X240M
Extension PC - Lian Li o11 Dynamic - Intel Core i9 9900k - MSI Meg Ace Z390 Mobo - 16GB Ram - RTX 3080ti - 256GB Samsung NVMe - Corsair AX850 PSU - CPU + GPU cooled with dual EKWB 360 Rads + G1 side EKWB distro plate.
Office PC - Thermaltake Tower 100 - Intel Core i7 8086K - Gbyte Z390 I Aorus Pro Wifi Mobo - 16GB Ram - iGPU - 256GB Samsung NVMe - EVGA B5 850W PSU - CPU cooled with dual EK Quantum Surface P120M Rads + Barrow 3-in-1 Block, Res & Pump.
Spare - Corsair 250D - Intel Core i7 8700k - Gbyte Z390 I Aorus Pro Wifi Mobo - 16GB Ram - GTX 980ti - 256GB Samsung NVMe - BeQuiet P11 750 PSU - CPU cooled with EK Coolstream S240 + S120 Rads + EK Pump / Res Combo
Annex - Corsair 280X - Intel Core i7 4790k - Asrock H97M ITX Mobo  - 16GB Ram - EVGA GTX 1080ti - Corsair SFXL600 PSU - CPU + GPU cooled with triple EK Coolstream S240s + EK Pump / Res Combo
NAS PC - Fractal Node 804 - Intel Core i7 3770k - Asus P8Z77-M Mobo - 16GB Ram - MSI GTX 1660 Ventus - Corsair AX850 PSU - Unraid 21TB Storage Server
Living Room AV Setup 5.1.4 - Nvidia Shield - Yamaha RX-A6A - 2 x B&W CM9s2 - 2 x Monitor Audio FX Silvers - 4 x B&W CCM665s - B&W CMCs2 - SVS SB13 Ultra - LG OLED65C1
Extension AV Setup - Sonos ARC + Sub (Gen 3) - LG OLED65C6V + Sonos Amp - 5 x Monitor Audio C265s
Bedroom AV Setup - Yamaha WXC-50 - 2 x B&W CM1s - Rel Quake - LG OLED42C2.
https://linustechtips.com/topic/1625108-wifi-issues-advice/
First, I assume you've gone through and ensured everything is fully updated. If not, do that.
Which Ubi APs in particular? Have you ensured they're all fully updated?
Have you used WiFi Man to map out your network signal?
Are these wireless APs? That will increase range at the cost of congestion.
There's a lot of troubleshooting we can do, but there is always the option of last resort: nuke it and rebuild the network from scratch. As long as you set the SSID and password as the same, all the client devices should pick it up (unless you're a doofus like me and accidentally change the SSID from Tell My Wifi Love Her to Tell My Wifi I Love Her, and proceed to spend 5 hours readopting everything before noticing the typo)
https://linustechtips.com/topic/1625108-wifi-issues-advice/#findComment-16815440
These are Wireless APs connected and powered via PoE back to the comms cabiniet that serves the main floor.
Yeh, thats kinda where I'm at with it and its pretty much what my security company told me to do. I really just can't be arsed spending an eveing here yoinking cables!
I think I'll just need to bite the bullet, get some choons on and get cracking!
https://linustechtips.com/topic/1625108-wifi-issues-advice/#findComment-16815489
Wait, so are they wireless or wired? If they're hardlined into a switch, I can't see why they'd be configured to have a wireless backhaul.
Also, seriously, grab Wifi Man and profile the network. It's a remarkably powerful tool
https://linustechtips.com/topic/1625108-wifi-issues-advice/#findComment-16815519
Sorry, maybe my terminology is wrong. They are wired APs back to a switch.
I'll give that a shot today, thx
https://linustechtips.com/topic/1625108-wifi-issues-advice/#findComment-16815726
Okay, good. I would describe that as "3 hardlined ubiquiti APs" because they are all wired into the network.
Are these actually separate APs? Or are both the private and guest networks being broadcast on the same APs?
This makes it sound like the problem is somewhere between the router and the clients. Could be a bad switch, bad cable, or bad AP, or very congested airspace.
And this says to me it's probably congested airspace. Are there any other businesses/residences within 50m of the restaurant?
BT operates on the the 2.4Ghz frequency, same as wifi. So you have 50 devices all pinging off potentially all the time. I'm not familiar with this specific brand, but a lot of BT implementations in IoT are less than ideal. I'd be interested in seeing what happens if you were to set the APs to 5Ghz only. I'm sure this isn't a feasible solution, I believe lots of POS systems don't support 5Ghz, but it could help identify the problem.
All that being said, wifiman should show lots of interference. If it does, you might be able to manually steer the APs (or maybe even the lights) to dedicated channels
https://linustechtips.com/topic/1625108-wifi-issues-advice/#findComment-16816184
