Ubuntu Help!
Go to solution Solved by Guest,
How can I move the Unity Launcher thing to the bottom of the desktop from the side? I NEED a solution.
installer a new desktop launcher it's easy
go to the terminal
  • sudo add-apt-repository ppa:gwendal-lebihan-dev/cinnamon-stable
  • sudo apt-get update
  • sudo apt-get install cinnamon
then log out and select a new launcher
not that i know of if you wanted linux with the bottom bar you should have gotten mint or something like that
Christian and Proud of it
Please read the CoC        My Build Log
https://linustechtips.com/topic/162375-ubuntu-help/#findComment-2161324
go to the terminal
https://linustechtips.com/topic/162375-ubuntu-help/#findComment-2161375
He can easily install a new launcher, mint is just a skinned ubuntu with a few tweaks
good point i forgot about different lauchers my bad
https://linustechtips.com/topic/162375-ubuntu-help/#findComment-2161396
Well thats not really true that cinnamon is just a "launcher/skin"
As of version 2.0 Cinnamon is a complete desktop environment.
Yes you can install cinnamon in ubuntu but mostly it is better to install
Mint in the first place with Cinnamon if you like more classic style of desktop.
https://linustechtips.com/topic/162375-ubuntu-help/#findComment-2163875
