hello guys I'm new here I just made an account I've been searching the internet the last 2 days for a solution because my 4090 RTX started ramping up the fans on 3000 RPM on idle and I do not know what to do I'm very sad at the edge of crying I spent 3 years saving money and I don't want to lose everything please help me. I was just watching stream on Twitch and all of a sudden there fans starting going berserk mind you I haven't downloaded anything the last week and I was not messing with it, the only thing that I've done I can think of is Windows updates but I haven't found any updates or information if that is true or not if Windows affected my graphics card fans AGAIN PLEASE HELP !!!
https://linustechtips.com/topic/1621243-please-help/
Okay, first of all, calm down.  Being frantic is never going to help.
Is this happening all the time or did it just happen once?
What is the rest of your system specs? Be specific.
https://linustechtips.com/topic/1621243-please-help/#findComment-16788973
It's going to be alright. The fans going crazy is not really indicative of anything major on it's own, so let's take a deep breath before moving on.
Let's start by getting some basic readings.
What are the full specs of your machine?
If you can, download HWMonitor and determine the temperatures of your 4090 while the fans are going crazy. Report back with those temps and we'll move from there
I sell teeth and teeth accessories 🦷
https://linustechtips.com/topic/1621243-please-help/#findComment-16788976
CPU: AMD Ryzen™ 9 7950X3D
Motherboard: Asus ROG STRIX X670E-E GAMING WIFI
RAM:Corsair DIMM 64 GB DDR5-6000
Keyboard: Everest Max - From Mountain
Mouse: Razer DeathAdder V3
Graphics card: ASUS GeForce RTX 4090 ROG STRIX GAMING OC
Monitor: Corsair Xeneon Flex 45WQHD240 OLED
SSD: Crucial T700 4TB PCIe Gen5 NVMe M.2
Big Tower case: Corsair 7000D Airflow TG
Power Supply: Corsair RM1200x 1200W
https://linustechtips.com/topic/1621243-please-help/#findComment-16788979
the temperature of the GPU is between 26 and 28 Celsius and I downloaded MSI afterburner NZXT and from Asus the GPU tweak 3 and the GPU reacts to none of them but the rest of the computer complies with the orders of these apps it's only the GPU that doesn't obey
https://linustechtips.com/topic/1621243-please-help/#findComment-16788982
if it only happened once then its fine, its a computer.. Weird things happen from time to time.
https://linustechtips.com/topic/1621243-please-help/#findComment-16788983
2 minutes ago, Valerios said:
but it's been 2 days isn't that way too long for the van to run on 3,000 RPM?
You only said it happened once and not that it staying at 3000 RPM's constantly.
You have to give precise details otherwise we dont know or cant understand what is going on.
So the GPU is still at constant 3000 RPM?
https://linustechtips.com/topic/1621243-please-help/#findComment-16788989
yes the  GPU is still at 3,000 RPM my apologies I probably did not explain that correctly
https://linustechtips.com/topic/1621243-please-help/#findComment-16788993
check for windows updates
check for drivers update
check for BIOS updates
check for chipset updates
reseat the GPU
one of these will work with high confidence, it's most unlikely that you have a thermal sensor problem in your GPU (i would say almost impossible),
nvidia drivers lately are bad, so you might even need to wait a bit for new ones to pop up, on the bright side your fans are at 100% all the time and not at 0%, your GPU is not cooking itself
                   -`                    y0ur5h4d0w@Darkness
                  .o+`                   -------------------
                 `ooo/                   OS: Arch Linux x86_64
                `+oooo:                  Host: Darkness
               `+oooooo:                 Kernel: Latest
               -+oooooo+:                Packages: Only what i need to keep it simple
             `/:-:++oooo+:               Shell: ZSH
            `/++++/+++++++:              Main Monitor: LG Ultragear LG 27GS85Q
           `/++++++++++++++:             Secondary Monitor: Asus MG28UQ
          `/+++ooooooooooooo/`           DE: Plasma Always Bleeding Edge
         ./ooosssso++osssssso+`          WM: kwin
        .oossssso-````/ossssss+`         Theme: Breeze-Dark [GTK2], Breeze [GTK3]
       -osssssso.      :ssssssso.        Icons: Breeze-dark [GTK2/3]
      :osssssss/        osssso+++.       Terminal: Kitty
     /ossssssss/        +ssssooo/-       Terminal Font: Noto Color Emoji 17 FreeMono 13
   `/ossssso+/:-        -:/+osssso+-     CPU: AMD Ryzen 7 9800X3D (16) @ 5.307GHz
  `+sso+:-`                 `.-/+oso:    GPU: AMD ATI Radeon RX 7800 XT
 `++:.                           `-/+/   GPU: AMD ATI Radeon Graphics
 .`                                 `/   Memory: 61830MiB
https://linustechtips.com/topic/1621243-please-help/#findComment-16789007
reseat the GPU
reseat the GPU? you mean turning off the computer unplugging the graphics card from the motherboard and replugging it?
https://linustechtips.com/topic/1621243-please-help/#findComment-16789010
Yes, but after you check the other options first
https://linustechtips.com/topic/1621243-please-help/#findComment-16789012
yes, correct, but before the reseat make sure the rest of the list is in an "ok" state
https://linustechtips.com/topic/1621243-please-help/#findComment-16789013
It's not really a bad thing, just an annoying thing. 2 days at full blast is not really that concerning long-term
https://linustechtips.com/topic/1621243-please-help/#findComment-16789014
OK i'm back said might as well clear the computer a little bit the graphics card looked pristine didn't have the spec of dust that was it just unplugging it and replugging it or "reseat" made it work correctly thank you very much dude and thanks to everybody here for helping me giving me advice when I needed
https://linustechtips.com/topic/1621243-please-help/#findComment-16789101
you're welcome ❤️
https://linustechtips.com/topic/1621243-please-help/#findComment-16789154
