Hi, all so I’ve always dreamed of doing an all asus rog build, well I’m working on it and I wanted to use the rog strix Helios case my only concern is the cooling with modern hardware, I was planning on going with a ryzen 7 9800x3d with the ryujin III 360 aio and lastly an rtx 5070ti, and I’ve heard mixed thoughts on the cooling of that case so I was wondering if anyone has any insight into how its doing with modern hardware and possible fan layout options, like which fans to use as exhaust vs intake, if possible I want the rgb fans for the aio to face inside (rgb side towards case) thanks in advance for any advice 🙂
https://linustechtips.com/topic/1620947-help-with-case-idea-and-cooling/
A 9800X3D and a 5070 Ti is actually quite easy to cool 🙂
I ran a overclocked 9800X3D and overclocked RTX 4080 for a while in a Corsair Graphite 760T with only 1 working front fan and 1 rear exhaust with a air cooler on the CPU, wasn't even close to thermal limits.
You'll be fine Helios.
